Hey guys, I’m battling an issue on my yenko. It has a really bad dead spot when lightly on the throttle. And if I step on it hard it will hesitate for a second then take off. I’ve adjusted and replaced accel pump with no change.
Does anyone know what number squirted should be on the 4346 Holley? Or have any suggestions ? Thanks!
1969 Yenko Camaro Lemans Blue 1969 Bill Hunter yenko camaro 1969 Berger copo original paint |
With the car not running and looking down the carb when you give it gas does the accelerator pump squirt right away, or is there a slight pause?
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am |
Have you checked the ignition timing? Retarded timing will cause a hesitation.
Check timing and rev it up with the vacuum advance hooked up to make sure it is working.
Make sure no vacuum leaks. Clean the idle and main air bleeds with some carb cleaner, especially if it has been sitting. I use a 31 squirter in my small block mild cam with headers Corvette. |
Another possibility is your primary power valve may be opening too soon causing the hesitation. When did this start happening? You may need to go down a # or two. It could be what other suggest. Goodluck......
Steve Shauger The Supercar Registry www.yenko.net or www.thesupercarregistry.com Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 06-09-2020 at 01:45 PM. |
To answer your initial question, the original squirter was .025.
You can go here, then save it as a pdf and keep it on your computer for quick reference. https://documents.holley.com/techlib...al_listing.pdf
Don't believe everything you read on the internet ... Ben Franklin |
Maybe the squirter size
Call Eric Jackson...
02 Berger 380hp #95 Lots of L78 Novas Join National Nostalgic Nova! 70 Orange Cooler 69 Camaro |
