Anyone have tips on on installing painted bolts without chipping the paint? I use a good 6 point socket but that doesn't always keep from knocking paint off.
Most of the body bolts were not painted. They were parkerized. Really easy to do, and you don't have to worry about chipping.
If you are dead set on painting, I have used done this in the past: Buff the bolt head on a wire wheel to make sure it is REALLY clean. Paint with a very thin layer of high heat paint. Bake the bolts at 400 degrees for 30 minutes. This will require some creative layouts to insure no part of the head is touching anything. Let cool. The resulting finish is so hard you will not chip it with a six point socket. Regular paint is going to chip unless you just don't tighten it down. Not recommended for obvious reasons.
Don't believe everything you read on the internet ... Ben Franklin |
| The Following User Says Thank You to Lynn For This Useful Post: | ||
drce500 (01-29-2020) | ||
I've used the nylon inserts that you can put in the sockets with good results.
The kit came with different sizes for the six point sockets. I originally bought them to protect the plastic lug nut covers used on my truck wheels but they have come in handy for other purposes. No idea where I bought them from though, it's been over 25 years. |
| The Following User Says Thank You to 69B Z28 For This Useful Post: | ||
I've got a set of those inserts. I think they came from Snap-On.
| The Following User Says Thank You to big gear head For This Useful Post: | ||
Eastwood used to sell the nylon insets for sockets. Worked great for molars w/painted body bolts and engine bolts
I often put a small piece of masking tape inside the socket, sticky side towards socket; extra thickness of paper helps keep good contact with the bolt flats. Also better quality sockets have less 'slop' than cheaper ones.
Tim in NSW, Australia 1969 Van Nuys 04A Z/28 from Clippinger Chevrolet. Cortez Silver with dark blue interior. Ran at Lions Dragstrip and Pomona Raceway, with paint by Bob Kovacs of Fresno. |
Seems like the only ones you can find at 1/2” drive and fir lug nuts. There is this option.
https://www.kctoolco.com/knipex-86-0...yABEgIgVfD_BwE
It's only Orig once I spend a lot of money on Wine, Women and Cars, I waste all the rest. 1978 Y88 1995 Q45 |
I believe Mac tools sells the "nylon" lined sockets that might work.
69 Chevelle SS L88 "Day-2" Lemans Blue 69 Chevelle SS L34 postsedan project-Azure Turquoise |
