Old 12-30-2019, 01:18 AM
big gear head's Avatar
Default '69 Camaro spindles.
I'm taking the original disc brakes off of my '69 Camaro and installing Aerospace brakes. I want to keep all of the original disc brake parts together. What I need to know is are the drum and disc brake spindles the same? I'm going to have the spindles off so that I can replace the bushings and ball joints in the control arms, so this would be the time to change the spindles. Also, are the steering arms the same?
Freddie
Old 12-30-2019, 10:21 AM
X66 714's Avatar
X66 714 X66 714 is offline
Disc & drum spindles are different. Disc spindles are machined different where the upper nut is. It's cut down to accept the thickness of the caliper mounting bracket. You can use your original steering arms...Joe
big gear head (12-30-2019)
Old 12-30-2019, 02:27 PM
Thank you. I had a set of drum brake spindles but threw them away several years ago. I wish I had kept them.
Freddie
Old 12-30-2019, 09:44 PM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Freddie there's a good article showing the disc/drum spindle differences at David Pozzi's site here: http://pozziracing.com/brakes.htm#disc_brake_spindle
Tim in NSW, Australia
The Following User Says Thank You to ZLP955 For This Useful Post:
Old 12-30-2019, 10:36 PM
Thanks guys. I think I found a set of drum brake spindles.
Freddie
Old 12-30-2019, 11:58 PM
bergy's Avatar
bergy bergy is offline
If the set of spindles that you’ve found don’t work out - I have a set that you ca have.
The Following User Says Thank You to bergy For This Useful Post:
big gear head (12-31-2019)
Old 12-31-2019, 02:40 AM
Thanks. I really appreciate that. I'll let you know if I need them.
Freddie
