Old 11-27-2019, 11:55 AM
Default 3908326 Brake Pressure Regulator Hold Off Valve
Hello folks-
Looking for the above part for a 02A 69 Camaro disc brake front drum rear 12 bolt car. I have seen a couple out on ebay but looking for a closer date to my car. Yes mine should have one based on the clean spot on the frame. Payment via pay pal friends and family.
Thanks, and enjoy thanksgiving!
Chris
Attachments - The Supercar Registry v3.jpg v2.jpg v1.jpg pressure regulator valve.jpg
Old 11-27-2019, 04:04 PM
I believe I have a January dated one. I can confirm when I get home this evening.
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
2019 Corvette Grand Sport
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
The Following User Says Thank You to luv2sixty9 For This Useful Post:
chris slawski (11-27-2019)
Old 11-27-2019, 05:10 PM
KevinW KevinW is offline
So where are the dates located? I have two, but grungy, so I need to know where to clean them.
69 327 convertible (driver)
The Following User Says Thank You to KevinW For This Useful Post:
Old 11-27-2019, 05:27 PM
jl8z28 jl8z28 is offline
Usally on the back
The Following User Says Thank You to jl8z28 For This Useful Post:
Old 11-27-2019, 05:42 PM
Chris,
The picture you show is where the clip goes that holds the brake line. The valve gets bolted after where the E-brake cable goes through the frame.
The valves are stamped on the front side and you would be able to see it looking at it in place on the frame.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
Old 11-27-2019, 06:08 PM
Default thanks Warren!
yes absolutely right, my mistake the residual is located closer to the end of the drivers side frame rail...it too is a clean spot!
Old 11-28-2019, 12:59 AM
I have a 016 - 9 (January 16th, 1969), along with several other dates
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
68 SS Lemans Blue
chris slawski (11-28-2019)
Old 11-28-2019, 06:33 AM
Default Hold off valve
PM sent
Old 11-28-2019, 11:57 AM
Default Pics
Chris,
Here are some pics of the valve.
It's in great shape and came off a 02B Build date 69 RS, which I had tag when removed.
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
68 SS Lemans Blue
Old 11-28-2019, 02:56 PM
Looks great! How much you thinking?
