Old 10-27-2019, 10:50 PM
KevinW KevinW is offline
Default 4-clip 15" trim rings, WIW
So I was cleaning out my garage today and happened to notice there were trim rings on the 15" FW rallys holding my project truck up. Two of them were the 4-clip style!
So are these the same trim rings used on 69 Z/28's? They are not too bad, but would need restoration to fix the rash and dents, etc. If same as the Z versions, would would they be worth?
Thx!
16" from outside edge to edge, 2 3/4" deep.
69 327 convertible (driver)
Old 10-28-2019, 12:15 PM
OK, doing some research this morning and rechecking my measurements. 2.5" high when measured vertically, 2.75" when measured across face with a football shaped valve stem hole. Also has a flat clip ring, no raised lip.
Looks like these are 67 Corvette and 69 Z28 1st design trim rings that matches part number 3901703. Don't see any recent Ebay items that match. With these needing restoration, value is tougher to nail down.
I guess the best thing is to throw them up on Ebay today and see what they bring.
Old 10-28-2019, 12:21 PM
NorCam's Avatar
NorCam NorCam is offline
Probably $100 to $150 a piece if the clips are good and they are pretty straight. A restored and polished set of 4 is typically $800 and up to $1200 for a concourse set. I bought a set of 4 from another member here last year for $750
Old 10-28-2019, 12:35 PM
Thanks! These are probably closer to the low end price
