Old 09-09-2019, 06:21 PM
JHS JHS is offline
Default 1967 Chevelle SS wheels
Having a little trouble identifying the correct code and size wheels needed for a '67 Chevelle SS396. I'm told it needs 15x7s and code DA and DG keep popping up but they seem to be 14x6s. I already have 3 restored '69 YH 15s so may just use those and find another.
'70 L78 NOVA SS
'77 Bronco
Old 09-09-2019, 07:18 PM
nova67 nova67 is offline
Default 67 chevelle wheels
14 inch wheels on 67 SS 396
The Following User Says Thank You to nova67 For This Useful Post:
earntaz (09-10-2019)
Old 09-09-2019, 09:26 PM
----My 67 disc brake SS Chevelle that I bought new had 14 inch rallys…….Bill S
Old 09-10-2019, 08:34 AM
Igosplut's Avatar
Igosplut Igosplut is offline
Mike still has his original hubcaps in a box that were taken off at Duarte's when they put on mag wheels right off the truck.
WOT
Old 09-09-2019, 10:40 PM
67 L78 67 L78 is offline
Disc brakes 14x6 DG rally's
Drum brakes 14x6 JK steel wheels A3 6 code
Old 09-09-2019, 11:47 PM
nova7579's Avatar
nova7579 nova7579 is offline
Originally Posted by 67 L78 View Post
Disc brakes 14x7 DG rally's
Drum brakes 14x7 JK steel wheels A3 6 code
No 7" wide 14" wheel was available in 1967. They did not come until 1969.
The correct code for a 1967 Chevelle with rally wheels were "DA" 14X5 on non SS cars and "DG" 14X6 on the SS cars. If it had stock steel wheels they were still only 14X6 on the SS cars.
ThanX
Brian
Old 09-10-2019, 11:47 AM
L72Biscayne L72Biscayne is offline
ThanX
Brian
Could the stock steel wheels come on a disc brake car?
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 09-10-2019, 12:26 PM
novadude novadude is offline
I think ALL disc brake cars got rallys in '67.
Old 09-10-2019, 12:55 PM
JHS JHS is offline
Thanks guys! I'm new to the 67 chevelle and kept getting conflicting info. about the size wheels. Just bought a matching numbers L78 and the seller kept saying it needed 15x7 rallys to be correct. They were installing 4 wheel disc brakes so I stopped that. I think the guy told me it was a power drum brake car and all 67 SS396 cars had rallys. I will have to dig a little deeper...
'70 L78 NOVA SS
'77 Bronco
The Following User Says Thank You to JHS For This Useful Post:
MYSTERYCHEVELLE (09-12-2019)
Old 09-10-2019, 03:35 PM
67since67's Avatar
Non-power drum brakes were std. on all '67 Chevelle SS 396, with power drum optional, both using 14x6 std wheels with A3 6 code or a variant of that code.
Optional disc brake SS 396 cars, non-SS ordered with PW7 white stripe F-70 and PW8 red stripe F-70, came std. with 14x6 DG code "Disc Brake" wheels. Disc Brake, or Rally Wheels as they became known as, were not available as a separate option in '67, only with disc brakes.
Last edited by 67since67; 09-11-2019 at 12:44 AM. Reason: Clarification to include non-SS cars.
L72Biscayne (09-11-2019)
