Old 08-20-2019, 02:18 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Idler arm boot
Does anyone have any suggestions about what I can do with this boot? Bottom right of the pic. It's my born with and is in otherwise perfect condition. I'd rather keep it. For now, I just keep it greased as best as I can. I drive it all the time...
IMG_20150705_131028 by Dave H, on Flickr
IMG_20150705_100744 by Dave H, on Flickr
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 08-20-2019, 05:49 PM
frankk frankk is offline
Some clear JB weld may work. Just keep it on the inner side
Old 08-20-2019, 08:51 PM
Spooky's Avatar
Spooky Spooky is offline
My Dad had a used car dealer friend that used to do a CV split boot kit that glued together to repair bad boots at a significant cost savings over changing out CV shafts. How about that glue?
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 08-20-2019, 11:04 PM
Danzo Danzo is offline
What about buying an aftermarket idler arm and robbing the boot of it?
Doc.
Old 08-20-2019, 11:58 PM
Doc.
From my experience the aftermarket boots are much different than the GM ones.
Old 08-21-2019, 12:38 PM
HawkX66's Avatar
Thanks for all the suggestions guys. I thought about buying a new or used one with the boot and robbing it, but like Rick mentioned, they're pretty different. If I could find an original I don't even know if I could get it off the old one without destroying it.
I might try the glue idea, but with the grease permeating the rubber for 50 years as of tomorrow..., I don't know if would hold.
-Dave
Semper Fi!
Old 08-21-2019, 01:02 PM
X66 714's Avatar
X66 714 X66 714 is offline
I thought I read somewhere that Corvette people had boots....Joe
Old 08-21-2019, 01:11 PM
HawkX66's Avatar
Thanks Joe. I'll check out Paragon and a few others and see if they know of anything.
-Dave
Semper Fi!
Old 08-22-2019, 09:00 PM
L78steve L78steve is offline
Glue it with 3M 5200 and a thin piece of fabric on the underside. Will take many days to set-up but will hold if cleaned with brake clean first.
The Following User Says Thank You to L78steve For This Useful Post:
HawkX66 (08-23-2019)
Old 08-23-2019, 12:20 PM
HawkX66's Avatar
Thanks Steve. I'll give it a look see. I really like the looks of the glue they use on the two piece CV boot repair kits. It looks like it really holds.
-Dave
Semper Fi!
