Old 02-26-2019, 03:20 PM
madden madden is offline
Default Deuce m21 input/output shafts & castings
HI
just going to have my deuce M21 freshened
wanting to ensure the shafts and the main & tailstock castings PART # are correct
what is the correct input and out put shaft spline counts
for 1970 DEUCE M21
they can be 10 input 27 output OR 26 input 32 output
what main housing and tailstock housing part #'s should i have
thank you
regards
chris
1970 citrus Yenko Nova
Old 02-26-2019, 08:54 PM
YENKO DEUCE REGISTRY's Avatar
The input shaft is 10 tooth. I believe the output shaft is 27 tooth, but not exactly sure - it's whatever a TH350 is....
Marlin
The Following User Says Thank You to YENKO DEUCE REGISTRY For This Useful Post:
madden (02-26-2019)
Old 02-26-2019, 09:56 PM
crash crash is offline
Originally Posted by madden View Post
HI
for 1970 DEUCE M21
thank you
regards
chris
You will need a...
661------- main case
648-------- side cover
584-------- tail housing
10 spline input
27 spline output
Very early 1970 production (August &September 1969) would use a 660 main case...
Hope this helps... Crash
Old 02-26-2019, 10:30 PM
thank you so much guys for the help with this
just want to make sure everything is correct prior to tranny shop freshens it........these things tend to get monkey with over the years...LOL
my M21 does have the 10 spline input and 27 spline output
the main case is the #661
the tailstock case is the #584
the side case cover is the #648
and the muncie I.D. tag on the side case is #3968011 WL (HOPE THIS TAG IS CORRECT?)
thanks again guys
regards
chris
Old 02-26-2019, 10:35 PM
crash
you seem to know a lot about these muncie trannies
my muncie I.D. tag on the side case is #3968011 WL
is this correct for my deuce
thx?
chris
