Old 01-03-2019, 07:50 PM
ScottG's Avatar
ScottG ScottG is offline
Default Help understanding GM vacuum advance codes
I am looking for an original GM advance unit. 1970 Buick GS350. A search finds a lot of them . Most have an M or an MS at the top. Then a three digit number that looks like it could be the last three numbers of the part number? Then a 2 digit number that could be the degrees of advance it gives? Thanks for the help...
1971 Boss 351 , 17,000 miles .. 1971 Buick GS455 .. 2003 SVT Cobra .. 1971 GTO .. 1969 Camaro Fathom Green .. 1969 Camaro Hugger Orange .. 1970 Buick GS455 .. 1970 BUICK GS350 .. 1998 SVT Cobra 1900 miles;. 1973 STAGE 1 GS . 1971 Mach 1 351C 4 speed , first car. 1970 Mach 1 428 SCJ . 1970 SS 350 Camaro . 1971 442 ... 1968 Buick GS400 . 2015 Lexus IS 350 F Sport 2021 Badlands Bronco Sport
Old 01-03-2019, 09:28 PM
John Brown's Avatar
What is your distributor number?
As far as your assumptions go, I'd say you are correct. I can look up your distributor in an old (1981) Delco Remy breakdown book and give you the number it lists for the distributor. Only caveat is, some of the sheets have replacement numbers instead of actual O.E. numbers. That's always a possible problem, part numbers superseded by GM.
John Brown
ScottG (01-04-2019)
Old 01-03-2019, 09:33 PM
The 2 numbers are the max advance built into the can.
More than you want to know about this is here:
https://www.crankshaftcoalition.com/...ance_Specs.pdf
The only other thing I will add is always obey the rule and the rule is always use non-ported vacuum.
Owned since 1978 - First Car
The Following 2 Users Say Thank You to BCreekDave For This Useful Post:
ScottG (01-04-2019), William (01-05-2019)
Old 01-04-2019, 12:47 PM
novadude novadude is offline
Originally Posted by BCreekDave View Post
The only other thing I will add is always obey the law and the law is always use non-ported vacuum.
Laws are made the be broken. Use what works best. On my car that is ported.
Ported was around since way before anyone ever thought about emissions. Don't believe all the garbage that gets regurgitated on the 'net about ported being for emissions only.
The Following User Says Thank You to novadude For This Useful Post:
ScottG (01-04-2019)
Old 01-04-2019, 10:25 PM
Flying Undertaker Flying Undertaker is offline
I have a May 1971 Delco TBA Parts Manual showing vacuum advance unit Delco part D 1328 for 70 Buick Special/ Skylark 350 v-8 Hi-compression as distributor # 1112006. It correlates to GM part #1116163. I hope this helps. Don.
The Following 2 Users Say Thank You to Flying Undertaker For This Useful Post:
John Brown (01-04-2019), ScottG (01-06-2019)
Old 01-06-2019, 03:05 AM
ScottG's Avatar
Thanks to all . I found one for $ 299.00 . Then I found one for $ 68.00 . Then the winner at $ 29.00 Evilbay search .
Old 01-06-2019, 04:20 AM
John Brown's Avatar
John Brown
ScottG (01-07-2019)
Old 01-04-2019, 01:13 AM
ScottG's Avatar
Engine code SP Dist. number 1112006
Old 01-04-2019, 02:37 AM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
Great info !
The Following User Says Thank You to KenMaisano For This Useful Post:
ScottG (01-04-2019)
Old 01-04-2019, 03:06 AM
John Brown's Avatar
My Delco book shows your distributor, number 1112006, uses a vacuum advance number 1116210. The sheet is dated 1978 and has about 25 different distributor numbers on it. I have no way of knowing what was changed on which of those distributors that caused that page to be updated. The short Delco number would be D1336. The 1116210 advance unit is stamped MS 210 16. I don't have any Buick parts catalogues from that time, but maybe you can find someone else that does.
John Brown
ScottG (01-04-2019)
