Old 06-22-2018, 02:48 AM
L_e_e's Avatar
L_e_e L_e_e is offline
Default Muncie ID
Picked this Muncie and ITM shifter up a couple weeks ago, can anyone tell me what it is?
From searching online it seems to have some conflicting characteristics.
Old 06-22-2018, 04:12 AM
ssl78 ssl78 is offline
Looks to be a 1969 trans with the casting number ground off should be a 660 case. The trans is a m20 2 grooves on input
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-22-2018, 11:14 AM
L_e_e's Avatar
And that is one of the things that is conflicting.
2 groove 10 spline input=M20 where the stamped number indicates M21
P = Muncie
9 = 1969
A = Janurary
02 = 02
B= M21
Old 06-22-2018, 12:12 PM
Wouldn't that be a 1970 or later side cover with the TCS switch on the 3-4 input?
Owned since 1978 - First Car
Old 06-22-2018, 01:43 PM
Some one rebuilt it and changed the guts, opriginally was a M21
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
L_e_e (06-23-2018)
Old 06-22-2018, 03:43 PM
You could put a mark on the input and output shafts, put it in first gear, and if the output shaft turns 2 and a half times with one turn of the input shaft, that would be a M-20 (2.52:1 ratio). An M-21 would turn a little less then that, at 2.20:1.
Old 06-22-2018, 04:51 PM
bbbentley's Avatar
If it has 2 rings on the input, you don’t need to turn it. There is no mix and matching of parts. It is a M20, period.
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
L_e_e (06-23-2018)
Old 06-23-2018, 12:56 AM
L_e_e's Avatar
Thanks for the replies, it's kinda what I figured, born a M21 and somewhere down the line someone converted it into a M20, which is what I wanted in the first place.
Still puzzling is to why someone would grind off the main case part number?
I can't think of a reason for doing that.
Old 06-23-2018, 03:51 AM
Maybe it was out of a stolen car years ago and some one thought it was some kind of identification number
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 06-23-2018, 05:08 PM
L_e_e's Avatar
LOL, good thing it doesn't have a vin stamped next to the date code.....
