Old 05-22-2018, 02:34 PM
bbbentley's Avatar
Default Looking for Filter Material Ideas for Air Cleaner
I would like to pick some member’s brains as to what they use for air cleaner filter material? I want to run velocity stacks I already have. At the top of the bell of each stack are 2 perforated screens to sandwich foam between. I could buy a furnace filter and cut to size. I don’t know if the foam is readily available? Any members have this dilemma and their advice?
FULL OWNER HISTORY
Attachments - The Supercar Registry Hood Ben inside 2.jpg flyeye4343.jpg 38632906_10157102611850260_430922761821487104_n.jpg
Old 05-22-2018, 05:01 PM
big gear head's Avatar
I'd try to find something that wasn't flammable. I caught my carburetor on fire about a dozen times Thrusday. If I had a foam filter on it I might not have a car now.
Freddie
bbbentley (05-22-2018)
Old 05-23-2018, 03:54 AM
Spooky's Avatar
Spooky Spooky is offline
Do boats have air cleaners or just a flame arrester? pretty sure everything in boats I think has to be non flammable.
69 Camaro RS/SS X22 4speed NOM but working on something special
69 Camaro x11 355 crossram m22 12 bolt 3.73's
Old 05-23-2018, 01:03 PM
I've seen boats with a woven stainless steel type filter, or flame arrestor. I don't know how well they filter, or how much air they will flow. I've seen velocity stacks with small round paper filters on top.
Freddie
Old 05-23-2018, 01:38 PM
bbbentley's Avatar
Not versed in boat setups, but I don’t think boats will provide much useful info except what Scott pointed out. That being, the flammability of a filter material, which is a good point.
I do not want anything sitting on top of the stack. Must be concealed below the top of the stack. Thanks.
FULL OWNER HISTORY
Old 05-23-2018, 06:25 PM
Turbo70Camaro's Avatar
Turbo70Camaro Turbo70Camaro is offline
Here you go bud few options on color, thickness and course or fine material.
http://shop.unifilter.com/p/red-coar...6-x-3-8-40-ppi
The Following User Says Thank You to Turbo70Camaro For This Useful Post:
bbbentley (05-23-2018)
Old 05-23-2018, 06:53 PM
bbbentley's Avatar
I like that. Red would look...well, red! Pretty cool. I am wondering if a flameproof coating or flame retardant spray is available? And how would that effect the filtration?
FULL OWNER HISTORY
Old 05-23-2018, 06:40 PM
Do you know if that foam fire resistant? I had the same flat-top velocity stacks on my car and swapped them out for the velocity stacks with the air cleaners on top as the fear of fire got the best of me, but I'd like to put the old flat ones back on it sometime if I can find something that is flame/fire resistant.
John 10:30
Old 05-23-2018, 06:51 PM
Give them a call it's only 11 am here in So Cal.
Old 05-25-2018, 08:26 PM
whitetop whitetop is offline
Just by looking at at it I would say no. Plastic based just like the MR G filters and they burn and melt.
