Old 02-12-2018, 10:37 PM
67 Nova Boy's Avatar
Default GM firewall pad rubber plug installation
Any tips on how to install the rubber firewall pad plugs that hold it in-place?
Repo pad with the better rubber, instead of the plastic plugs...having a hard time getting
them in.
Dave
67 Nova Boy
Old 02-12-2018, 11:29 PM
Unreal Unreal is offline
I used a rat tail file a little smaller as the hole in the plug, and pushed it through the firewall. It stretches rubber, and reduces its diameter. Had to push pretty hard, as I recall. I'm thinking I used a little silicone spray on the plug to make it slide easier.
Old 02-13-2018, 02:02 AM
Thanks for the tip...will go at again tomorrow.
Dave
67 Nova Boy
Old 02-13-2018, 03:36 AM
L78steve L78steve is offline
Something with a blunt end so not to push through the rubber.
The lube suggestion is a good idea.
Old 02-13-2018, 04:01 AM
Kurt S Kurt S is offline
IIRC, they used soap in the plant.
Kurt S - CRG
Old 02-13-2018, 04:31 AM
L78 Fred L78 Fred is offline
Dave,
I have a tool for it, you are welcome to borrow it
For anyone in construction it is nothing more than a steel drop in anchor set tool
like a drift punch with a step in it
Fred
[email protected]
610-585-4155
WANTED:
Old 02-13-2018, 12:43 PM
BLACKLS5 BLACKLS5 is offline
I rounded off a Phillips head screwdriver and welded a washer on it the same depth as the bottom of the retainer so washer is pushing on the head and the blunt end of the screwdriver is pushing on the point of the retainer at the same time. I'm talking about the hard plastic retainers but I would think that it would work on rubber also.
Old 02-13-2018, 12:59 PM
Some really creative solutions for these pesky little plugs! Will give them a try today...
One of those hold ups that must be done...
Thanks all for the tips!
Dave
67 Nova Boy
Old 02-13-2018, 01:28 PM
bluel78 bluel78 is offline
Any tips to save the originals?
Old 02-13-2018, 01:40 PM
NorCam's Avatar
NorCam NorCam is offline
Often easier to install a couple bolts up top to hold the pad straight for the first couple plugs to go in Dave. Dawn dish soap serves as a great lube to get then in.
