Old 10-10-2017, 11:35 PM
bergy's Avatar
bergy bergy is offline
Default L78 horsepower
Made our first dyno run on the L78 engine for my 67 Camaro. It's bone stock carb to pan. Generated 397hp at 5,500. Was running a little lean, so re-jetting tonight and run again tomorrow. Anyone have input on what HP a stock L78 should put out?
Attachments - The Supercar Registry PhotoScan.jpg 396 dyno (3).jpg IMG_2706.JPG FullSizeRender.jpg 427 dyno.jpg
Old 10-11-2017, 12:57 AM
bluel78 bluel78 is offline
Was the session with headers or exhaust manifolds? Ours with a little lower compression made 450 with the shops carb, headers and dist. but almost 70 less with the stock carb and distributer.
Old 10-11-2017, 01:06 AM
mockingbird812's Avatar
The answer is.... has Eric laid his hands on it or not!!
Sam...
Old 10-11-2017, 01:40 AM
wheelhop wheelhop is offline
Mine made 420 with shop headers but, was not "dialed in" all the way
Old 10-11-2017, 01:45 AM
luzl78 luzl78 is offline
How much do you think headers add over manifolds? Eric is gonna build my 402 for me and I am going back and forth. It's in my Monte Carlo.
Old 10-11-2017, 04:09 PM
VintageMusclecar's Avatar
When I built Donnie Cornelis' `69 L78 it made 462 HP and 439 lb.ft through headers (which were too big for that engine but were all I could get my hands on in time to test with) and ~430 HP and 411 lb.ft through the manifolds. However, the peaks don't tell the whole story. The engine lost 60+ lb.ft down low with the manifolds in place, and that you will definitely notice.
Old 10-11-2017, 01:51 AM
bergy's Avatar
Eric did the carb. Ran on dyno with headers, stock dist and carb.
Old 10-11-2017, 02:15 AM
Seems impressive to me. Was max HP at 5500? Seems to me there would had been a little more runway left for more HP?
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 10-11-2017, 03:08 AM
Should take roughly a 74 primary jet with headers on the dyno, will want the 71 with manifolds in the car. Secondary jetting should be good as is.
Old 10-11-2017, 01:34 PM
Post L78 Horsepower..
When the L78 was introduced in 1965 it was rated at 425hp...this was based on 6400 rpm's...almost 1,000 rpm lower than the engine being discussed. Most folks would agree that the later 375hp rating was low...headers, properly tuned distributor/carb and blueprinted assembly all make a huge difference.
Last one we did was a 70 402 version...pancake intake, Eric prepared 4492 and run thru headers...it made north of 430hp.
Again, the real power difference in these motors is in the details.
-wilma
ORIGLS6 (10-15-2017)
