Old 08-02-2017, 04:55 PM
Default Hood hinge replating (not rebuilding)
I'm trying to find a source to replate hood hinges with the gold zinc dichromate without taking them apart or blasting them. They need degreasing and a chemical stripping, then replating. The springs also need to be removed, stretched, blasted, repainted with semi-gloss black and reinstalled.
I tried SMS but they won't do it. Any suggestions?
Verne
Attachments - The Supercar Registry Spring1.jpg IMG_1820.JPG IMG_1819.JPG Hood spring spreader.JPG
Old 08-03-2017, 01:00 AM
mockingbird812's Avatar
Verne - went thru this process recently. Mikey M22Mike was a big help. He showed me how to make a simple jig to keep the springs spread for a good plating process. I am still determining my local restoration capabilities (i.e. I don't have media blasting cabinet at present) being new to Dayton. So with that said I paid up more than I wanted to, but I wanted to keep it local. I am VERY pleased with the results. I had my hinges glass bead blasted and then used a local plater to do a dark grey (phosphate in my case) finish. I left my hinges in one piece (except removing springs) and they took the plating very well. Check with your local chroming shops as they may have insight to good platers to give you a gold zinc dichromate finish - this is what I did. They took my hinges (and other hood hardware and fasteners) to a local industrial/military platers. This plating company would not take my project on but would take work from the chroming company.
Sam...
Old 08-03-2017, 02:55 AM
Thanks to you and Mike Sam. I heard back from a plater who can do the hinges, but I have to do the springs. I'll make up a plate like yours to keep them spread open for blasting and painting.
Verne
Old 08-03-2017, 01:13 PM
bluel78 bluel78 is offline
That's a good idea to keep the springs spread, how do you install the spring without damaging the new plating?
Dustin
Old 08-03-2017, 01:33 PM
jasonL78 jasonL78 is offline
I've done the same thing with a 2x4 and a couple of lag bolts to get the springs spread. same concept just a little more redneck....LOL
Looking for the next project.
Old 08-03-2017, 02:16 PM
XXXGoldL34M20's Avatar
Dustin
Not my spring in this photo but I did the same thing.
Stretch spring on your Hydraulic jack then add a bunch of shims in between.
Should pop right in with hood all the way up, then close hood 3/4 down and some shims will just fall out or you can pull them out by hand as the tension is gone.
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post:
parkbrau (08-04-2017)
Old 08-03-2017, 02:56 PM
That's a good idea.... I wouldn't stretch it that far. I would use paint stick instead of shims those could chip the paint.
Old 08-03-2017, 03:20 PM
I saw the floor jack trick on a U-tube video. Also, someone used a Port-a-power to spread the springs to get them off the hinges. Hinges were off the car like mine are, so I can't use the hood to stretch them.
I don't think I'll do that near the car though, just in case I create a missile.
Verne
Old 08-03-2017, 03:56 PM
I agree, Popsicle sticks will work too.
Old 08-10-2017, 04:11 AM
bptactical bptactical is offline
If you can boil water you can re-parkerize your own components and save $$$$.
Degrease, blast (but you really need something more aggressive than bead blast) and put it in the solution until it stops bubbling (off gassing).
Rinse and oil.
