Old 06-12-2017, 08:08 PM
day2killa day2killa is offline
Default mh slick size? and wheel size?
I want to put a set of slicks on my 69 chevelle to do a few passes this summer any recommendations on size am I on the right track for the correct day 2 look.
https://www.cokertire.com/tires/styl...ck-900-15.html
http://www.ss396.com/part/NSK-68157.html
Old 06-12-2017, 08:50 PM
Jim Ferron Jim Ferron is offline
Use 7 in rally wheels...that what would have been in it back in the day...Plentiful then and now.
www.68hurstolds.com 'Russ Dunmire Hurst Olds'
www.classicperformance.com 'Cars'
Old 06-13-2017, 01:38 AM
mockingbird812's Avatar
My '69 Chevelle ran this back in the day:
Yes to the M&H Cheater slicks 9.00-15 which are 29 1/2 " tall and fit real well and fill out the wheel well nicely (as can be seen below). Wheels could be steel wheels and could be 15" Vintique62 series. Jegs carries both.
This is how my car looked at the drag strips in VA and NC back in 60s early 70s. Notice beneath the car that the rear exhaust pipes are hanging off the lower bolt hole of the headers...
Sam...
Old 06-13-2017, 01:51 AM
that's the look, perfection
Old 06-13-2017, 01:54 AM
do you know what back spacing
Old 06-13-2017, 02:00 AM
I do not know. Will have to research that.
Hey Grady - you got yr ears on?!!!!!!!!!!!!
Sam...
Old 06-13-2017, 03:23 AM
1969grb 1969grb is offline
I probably would use a 15x7 with a 4 or 4 1/4 backspace. Should have plenty of room.
Grady
Old 06-13-2017, 02:24 PM
Mr. Day Two has spoken!!!
As luck would have it, the Vintique wheels listed here ( http://www.jegs.com/i/Wheel-Vintique...34044/10002/-1 ) are 15x7" and have a 4 1/4 backspace.
Thanks Grady!
Sam...
Old 06-13-2017, 03:21 PM
BillD BillD is offline
I bought a pair of the repro steel wheels a few years back. I did not notice that the center hole is over sized on the repro until I mounted the tires and put them on the car. It did not look right to me.
Old 06-13-2017, 03:25 PM
Which manufacturer did you buy Bill?
Sam...
ls6shadowgray (06-13-2017)
