Old 02-21-2017, 02:30 AM
L78_Nova's Avatar
L78_Nova L78_Nova is offline
Default L78 Nova Rad Help
Installing a 68 Camaro BB 4 core rad into my 70 Nova. Bolts in OK but just want to check if it is supposed to be set back from the cradle this much ?? 3/8" gap from tank edges to cradle and only 1-3/4" between pump pulley and rad.
I can Squeek in a flex fan using a 1/2" spacer (required to clear the alternator and lower pulley) but it is TOIGHT LIKE A TOIGER ??
Am I missing something ?
Pics to follow..,
Thanks for any input Gary
70 Chevelle SS-454 LS-5 M-22
The Following User Says Thank You to L78_Nova For This Useful Post:
mprice (09-04-2018)
L78_Nova's Avatar
Default Re: L78 Nova Rad Help
Old 02-21-2017, 02:31 AM
L78_Nova's Avatar
Old 02-21-2017, 02:32 AM
L78_Nova's Avatar
Old 02-21-2017, 02:35 AM
L78_Nova's Avatar
The rad was original from an ss396 68 Camaro but may have been recored. It was missing the tabs for the lower shroud hooks. I fabbed some up to mount the shroud.
Gary
Old 02-21-2017, 03:29 AM
cwc's Avatar
cwc cwc is offline
The gap between the radiator and core support looks a little wide, I'll take a pic of mine and post tomorrow night,originally a 396 nova had no spacer between fan and water pump pulley
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
Old 02-21-2017, 12:51 PM
L78_Nova's Avatar
I believe originally it would use a clutch fan ?? correct ??
I don't think a clutch fan would fit in the 1-3/4" gap.
Are the original Nova rads only 3-core?
Thanks for your help.
Gary
Old 02-21-2017, 02:52 PM
Big block Novas used a 3 core radiator. No clutch fan and no spacer. Stock fan was a 5 blade type, bolted directly to pump pulley. Even with a 3 core, it's close to the fan... A 4 core will work. Some guys do have 4 cores on there BB Novas.
Old 02-21-2017, 02:55 PM
L78_Nova's Avatar
What is the correct Fan PN I should be looking for ?
Old 02-21-2017, 03:21 PM
The correct fan is the steel 5 blade unit...2 of the blades are offset...as mentioned it bolts directly to the water pump flange.
The only year for a clutch fan with BB was 1968...but, there was a short water pump that year.
I have a 4 core in our 70 BB TH400 L78 car...it's tight, but it works.
Your photos seem to show a wider space than I remember...but, I'll have to check to be sure.
-wilma
