Old 11-10-2016, 01:17 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Sheared off bolt
Wondering how to come at this to get it out. Or if I do anything at all. Good 660 thermostat housing on a '70 LTI intake...oy
Any ideas? Thanks
Old 11-10-2016, 01:21 PM
L78steve L78steve is offline
Default Re: Sheared off bolt
Simple. The bolt is most likely frozen in the housing not the threads. Let someone that has experience with these situations deal with it.
Old 11-10-2016, 01:54 PM
Tracker1's Avatar
I live on an island off the east coast of Canada - most here want to attack it with a sawzall. it's all on me. If I may reference your signature quote by Faber - "knowledge is good". I need knowledge. Thanks.
Old 11-10-2016, 02:16 PM
Can't you use an Easy Out for that?
Old 11-10-2016, 02:38 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Can you get the other bolt out, lift the t-stat housing off the intake and then after soaking the threads on the broken bolt with penetrating oil use vise grips to remove it?
Jake Dykstra
Dykstra Motorsports
Old 11-10-2016, 02:47 PM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RPOLS3</div><div class="ubbcode-body">Can you get the other bolt out, lift the t-stat housing off the intake and then after soaking the threads on the broken bolt with penetrating oil use vise grips to remove it? </div></div>
No, the sheared off bolt is holding the t-stat housing into the intake
Old 11-10-2016, 02:54 PM
bbbenny bbbenny is offline
Hit it with WD-40 and let it sit for day or two. BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 11-10-2016, 03:15 PM
Tracker1's Avatar
Been doing that for a couple months Benny, yup. I haven't been considering heat or drilling in this situation Jason. But I think I may just have to sacrifice that 660 [img]<<GRAEMLIN_URL>>/frown.gif[/img]
I do have any easy out, just been hesitant to use it...
Old 11-10-2016, 04:52 PM
njsteve's Avatar
njsteve njsteve is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RPOLS3</div><div class="ubbcode-body">Can you get the other bolt out, lift the t-stat housing off the intake and then after soaking the threads on the broken bolt with penetrating oil use vise grips to remove it? </div></div>
No, the sheared off bolt is holding the t-stat housing into the intake </div></div>
So the short bolt is removed or still in the housing? If you can get the short bolt out I would try to rock the housing clockwise and ccw just to get some movement (using a ton of penetrating oil and a wooden or rubber mallet)
Old 11-11-2016, 04:08 AM
Kurt S Kurt S is offline
I'm confused. The t-stat housing isn't threaded - those are clearance holes in the housing. Remove the other bolt. Work the housing loose and remove it. Then remove the sheared off bolt.
Kurt S - CRG
