Old 09-15-2016, 03:47 PM
HoH HoH is offline
Default 1970 Chevelle SS L34 396 - Numbers Matching
1970 Chevrolet Chevelle SS 396. A real and documented numbers matching example of one of the pinnacles of the muscle car world. Originally sold in in Kansas and then spent time in Texas until the current owner purchased it in 1980. Countless hours have been spent reconditioning, and detailing every aspect of this car over his years of ownership. The original build sheet and Protect-O-Plate are included and authenticate every option on this car is correct.
Body/Paint/Exterior Trim:
Solid and rust free body received one correct color lacquer repaint in the mid 80's. Some light scratching/checking and some imperfections are coming through mostly on the hood and trunk (very hard to see in pictures). A few small paint chips and small dings are present from use, but overall the paint shows well, has great gloss and is very presentable. Chrome is nice condition with no pitting or rust areas. Original looking stainless trim is straight and shines nicely, but does have some light scratching in areas from age. Weatherstripping is in good shape and there are no leaks. Trunk and cabin floors are clean, solid and rust free.
Interior:
Front seat covers and carpet were replaced around the time the paint was done and both still look great. The rear seat looks like no one has ever used it. Door panels, side trim, front seat backer boards and headliner is all original. There are some small imperfections in the headliner and scratches in the seat backer boards from age and use. Dash is uncut, crack free and still looks great. Ammeter is inop and fuel gauge reads a little off, but all other gauges work as they should. The only deviation from stock inside is a Sanyo stereo circa 1980's. Window regulators work smoothly and there is no binding with the manual lock assemblies. While this is an A/C car and all the components are in place, there is no charge in the system. Heater and blower motor are all operational. Power steering and brakes are all in good working order.
Engine/Drivetrain:
Original VIN stamped "L34" 350HP 396 (402 cubic inches for 1970) engine that was rebuilt in the 80's, bored .030 over with a Comp Cams hydraulic flat tappet cam installed. The engine is mated to the original VIN stamped "M40" Turbo-Hydromatic 400 transmission that shifts well with no issues, a slightly higher than stock torque converter was installed for improved drivability. Out back is the correct date coded, 3.31:1 geared 12 bolt posi-traction rear end to round out the original drivetrain. Carburetor and distributor are numbers matching pieces as well. All maintenance is up to date. This car was built to be driven and enjoyed without worry, ready for your cross country adventures!
Attention to detail:
Wherever you look there is attention to detail. From the beautiful engine bay, to the clean and detailed undercarriage, the good complete interior and rust free, straight and solid exterior, this car will not disappoint. It is a perfect entry point for someone that wants a numbers matching 1970 Chevelle SS without the nut and bolt restoration price point. It can be driven and enjoyed as is, or easily taken to the next level. For the price of some of the clones out there, you can have a documented, numbers matching, real deal piece of muscle car history!!
VIN: 136370K180912
VIN Breakdown:
Year -- 1970
Series -- (36) Malibu, V8 Engine
Body Style -- (37) 2 Door Sport Coupe
Plant: (K) Kansas City, MO
Cowl Tag Breakdown:
Line 1
Model Production year -- 1970
Body Style Number -- (13637) Malibu Sport Coupe
Final Assembly Plant -- Kansas City, MO
Fisher Body Number - 856754
Line 2
Interior trim -- (756) Black Coated Fabric
Exterior Paint Code -- (17) Shadow Gray
Line 3
Body Date -- (03C) Third week of March
Data Processing Numbers -- (04041)
Body description code -- (L) Malibu Sport Coupe
Engine Pad Breakdown:
T0311CTW
Engine Plant -- (T) Tonawanda plant
Assembly date -- (0311) March 11th
Engine/Transmission Code -- (CTW) L34/M40, 350HP 396 (402), TH400 Automatic Trans
VIN Code: 10K180912
Transmission Pad Breakdown:
Top line -- (426) 426 days from Jan 1, 1969 or March 3, 1970
Bottom Line -- (70-CF-22286)
70 -- 1970 Model Year
CF -- 350HP 396 (402)
22286 -- Serial Number of Transmission
VIN Code: 10K180912
Rear axle Breakdown:
CCF 0302B2
Axle code -- (CCF) 3.31.1, 12 Bolt Positraction
Assembly Date -- (0302) March 2, 1970
Assembly plant -- (B) Buffalo, New York
Assembly Shift -- (2) Second shift
Carb Code Breakdown:
Top Line -- 7040204 FF
704: 1970 -- 1975
0: 1970
2: Quadrajet
0: Chevrolet Division
4: Automatic Transmission
FF: Customer code seen on block 18 of build sheet
Bottom line -- 0550
055: Build day, February 24
0: Build year: 1970
High resolution pics:
No Trades!
$36,995.00
John
414-333-0686
Old 09-15-2016, 05:52 PM
Default Re: 1970 Chevelle SS L34 396 - Numbers Matching
Very well done and thorough ad. I would LOVE to have that sitting in my garage waiting to be driven and shown. It is beautiful. Good luck on the sale.
Rick
Old 09-15-2016, 08:19 PM
bbbentley's Avatar
That! Is one Super Car GLWS
FULL OWNER HISTORY
Old 09-16-2016, 12:41 AM
Mr. Chevy's Avatar
Very nice car and very good,detailed description!! If I had the $$$ and space I would love to have it!!
Good luck with your sale...
Rich
Old 09-16-2016, 01:42 AM
Oh Donnie [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-16-2016, 01:50 AM
Very nice.And an L-34 with the optional T60 side terminal battery as well.You don't see many L-34's with that,as well as the optional extra amp K85 Alt. upgrade.Not surprising,as besides AC,it also received the optional Convenience group &amp; the Auxiliary Lighting group,which meant it needed those extra amps.
Those stripes are nice,but were applied long after delivery and not during factory assembly originally.
VIN 136370K180912
Old 09-16-2016, 10:50 AM
HoH HoH is offline
Thanks for the kind words guys! Sale pending...
Old 09-17-2016, 11:40 AM
HoH HoH is offline
Car is sold, mods can delete!
Old 09-17-2016, 12:53 PM
John's Avatar
John John is offline
.... Love that color [img]<<GRAEMLIN_URL>>/worship.gif[/img]
