I have a heavily modified '68 Camaro with a built 302 and a Muncie Transmission. Previously when cruising in 3rd or 4th gear, I could hear a deep growl coming from the flywheel/bell housing area. Car ran fine, clutch engaged and disengaged as it should and it shifted without problem; I just heard a different growling noise. So yesterday I tried to start it up, and it emitted a very loud grinding noise and didn't start. I tried just a couple short times to start it but I stopped due to the grinding noise. I have my suspicions as to what it could be but wanted to get the experts opinions from here. Appreciate any help, Mark
1968 Camaro Ex-ISCA Show Car - Sold ![]() On The Lookout For My Next Classic... John 10:30 |
probably either a starter drive or ring gear problem.Sometimes on higher compression engines if it does not have the strarter brace the starter cocks while trying to start it and loosens the starter bolts a little, especially if it back fires. Try to loosen the 2 starter bolts and realighn it. You should also look to see if you have the shouldered knurled starter bolts.
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am |
If you need to drive the car into the shop, rotate the engine and give the starter another try although if it works, the ring gear may be chewed at the dead spot? Good luck! [img]<<GRAEMLIN_URL>>/beers.gif[/img] ~ Pete
I like real cars best...especially the REAL real ones! |
Haven't had a chance to crawl under the car yet. Is there any way that the starter could have been stuck in the "contact" position? Would that have resulted in the growl that I heard while driving, or if the starter remained in contact with the flywheel, would have been a different sound? Just wondering, thanks.
Mark -- if the starter was engaged while engine is running, you would certainly hear it unless you're running open headers. To check alignment of the starter, pull the flywheel cover and using a .125 drill check clearance between the starter shaft and the ring gear -- that will get you close. Also, as John and Pete have indicated earlier, check the bolts and insure the knurled portion of the bolt is not worn away and the ring gear is not chewed up. TAZ
You've never lived until you've almost died -- for those who fight for it, life has a flavor the protected will never know! |
Mark -- here is an illustration of how to check the clearance.
Thanks Taz.
OK, found that my starter loosened up from when I fixed it previously (I guess I didn't tighten it down as much as I should have), and when I tried to start the car after a few times of fixing it, it apparently screwed up some teeth on the flywheel (Muncie trans). I got it tightened up and took it for a ride and it runs fine, but one time I started it, I heard the starter engage the chipped teeth but it has fired up numerous times.
So now I suppose I have to swap out the flywheel. Do I have to buy the entire new flywheel or can I swap out the flexplate part of the flywheel? Wasn't sure if they were manufactured with the ability to change out the flexplate or if the whole deal needs to be swapped. This all new to me, so I appreciate your thoughts and comments, thanks, Mark
Just replace the ring gear. knock off the old one, heat the new one with a torch and drop it on.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
The actual ring gear is very inexpensive and simple to replace like Steve says. More of a pain to have to remove it from the engine than anything.
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
