Old 07-30-2016, 08:54 PM
69biscayne 69biscayne is offline
Default 69 camaro cowl induction air cleaner
I was at a swap meet and saw a 69 camaro (SS 350) cowl induction air cleaner for sale. (OEM not a reproduction). It looked complete and in good shape. What is it worth? I don't have a camaro but that doesn't stop me from buying interesting parts.
Steve
Old 07-30-2016, 09:57 PM
William William is offline
Default Re: 69 camaro cowl induction air cleaner
Depends on the application and how complete it is. Original ZL2 air cleaners had a flat bottom until approximately Sep '69; all used the same flange & seal.
For some time GMPD service air cleaners were furnished with a chrome lid; was never used in production. The later service flange was clipped for some reason.
SS350/manual trans - has the tall extension for the flange/seal assy.
SS350/auto trans - same as above but has the vacuum valve in the snout for the CCS.
396/427 all - no extension. Serviced for many years by GM; was the later unit with the stamped bead in the bottom. Later reproduced. Common and still available.
302 Z/28 - same as BB but used a short extension to raise the flange/seal assy.
'70 Chevelle SS used the same as Camaro. '71 - '72 Chevelles are somewhat different I believe.
Of these the true SS350 units are hardest to locate.
Old 07-31-2016, 12:01 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: William</div><div class="ubbcode-body">
396/427 all - no extension. Serviced for many years by GM; was the later unit with the stamped bead in the bottom. Later reproduced. Common and still available.</div></div>
Didn't ONLY the ZL-1's have a completely symmetrical metal ring flange too,because no ZL-1 came with AC?
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">'71 - '72 Chevelles are somewhat different I believe.</div></div>
True,these have the unique heat stove/thermac pot on the snorkel.
Old 07-31-2016, 02:33 AM
All '69s had the fully symmetrical flange.
The clipped flange appeared in the '70 model year. Looking at a vintage test of a Chevelle SS396 w/AC there is a vacuum can mounted on the firewall above the rh rocker cover. It is very close to the flange/seal so possibly that is the reason for it.
