Old 07-17-2016, 10:25 PM
napa68's Avatar
napa68 napa68 is offline
Default Muncie Shifter Issue
Perhaps, some can shed some light on a problem I am having. The Muncie shifter in my 68 Camaro will not allow me (all of a sudden) not shift into reverse. It is like the gate (to move it to the left before shifting up) is not there.
Anything I should be looking for? Otherwise, it shifts 1-4 just fine.
Tim
Old 07-18-2016, 01:04 AM
crash crash is offline
Default Re: Muncie Shifter Issue
The reverse detent spring loaded button is likely the problem...
Theres an open spring that loads the shift lever to the 3-4 gate, you have to over come that spring to get to the 1-2 gate...
Once into the 1-2 gate you have to over come the reverse button also...
Or any number of things(broken reverse lever in shifter, dirt or debris, etc)...
Hope this helps... Crash
Old 07-18-2016, 04:20 PM
Also check to make sure you can shift the transmission into reverse manually using the lever only with the rod removed.
Old 07-18-2016, 11:53 PM
napa68's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">Also check to make sure you can shift the transmission into reverse manually using the lever only with the rod removed. </div></div>
That I can. Wanted to rule out the trans [img]<<GRAEMLIN_URL>>/no.gif[/img]
