Old 07-17-2016, 02:29 PM
JRSully JRSully is offline
Default battery spitting acid
The Nova seems to be spitting acid through the vent after a drive and making a mess. Anybody have any simple tests to see if it the alternator or voltage regulator is to blame here.? Thx for the help
71 Porsche 911 Targa
Old 07-17-2016, 03:05 PM
Default Re: battery spitting acid
Why are you still using a wet battery?
I got rid of mine when the industry came out with the solid R-59 Gel many many years ago.
I had your problem and it was usually do to a cell being too full of electrolyte/distilled water,or the cell not being able to breathe due to the cap filters being clogged and needed cleaning.
I'd clean by soaking in a 50/50 mix of baking soda & water periodically.
Old 07-17-2016, 04:13 PM
Probably right with that statement. Just want to check the V reg and Alternator to make sure there are no issues there, cause if there is a problem, wont matter what kind of battery I have
Old 07-17-2016, 04:47 PM
Kurt S Kurt S is offline
Measure the voltage at the battery while running. If it's too high, that could cause it.
Kurt S - CRG
Old 07-17-2016, 05:45 PM
What Kurt said, 1st thing to check.
Mike
Old 07-17-2016, 06:22 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kurt S</div><div class="ubbcode-body">Measure the voltage at the battery while running. If it's too high, that could cause it.</div></div>
X2!!
Old 07-17-2016, 08:11 PM
PxTx's Avatar
PxTx PxTx is offline
Don't rule out the battery having an internal short. You'll need a professional style battery charger (not one of those little guys).
If you can get something like 20 amps going into the battery and a separate volt meter at the battery and it reads 15v or greater, it likely is shorted internally.
These internal shorts can cause your alternator to full field when driving down the road aND bois off the good cells.
Paul III
Old 07-18-2016, 12:37 AM
All good info. Thx folks
