Old 07-06-2016, 03:39 PM
Crossbreed383 Crossbreed383 is offline
Default 1968 BB Nova Parts List Help Needed
Need help for who makes the following most correct looking parts for a big block 68 Nova
BB Radiator shroud
Shroud install kit- Not really sure what parts I need to install it to core support????
Upper radiator hose
Bypass hose from manifold to pump and correct nipples for those and heater hoses ?
Thanks in advance
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
Old 07-08-2016, 12:10 PM
jasonL78 jasonL78 is offline
Default Re: 1968 BB Nova Parts List Help Needed
So you are putting together a 68 BB nova? Is it an original BB car? They do reproduce a 68 BB shroud I think and think it is the same one for Camaro? Same with the top radiator hose. The bracket on top is 68 BB nova only and no one reproduces it. You need an original to duplicate it. The by bass hose should be the same for all 68 BB cars I also don't think that is 68 nova specific.
Here is the top bracket.
Looking for the next project.
Old 07-08-2016, 03:40 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jasonL78</div><div class="ubbcode-body">So you are putting together a 68 BB nova? Is it an original BB car? They do reproduce a 68 BB shroud I think and think it is the same one for Camaro? Same with the top radiator hose. The bracket on top is 68 BB nova only and no one reproduces it. You need an original to duplicate it. The by bass hose should be the same for all 68 BB cars I also don't think that is 68 nova specific.
</div></div>
Originally a nice clean radio delete 6 cyl car
But looking to make it look as original as possible as I cant afford the real thing lol
Have some other questions as well if that's ok
Thanks
Nick
Old 07-08-2016, 05:09 PM
Sure shoot me a PM and I will give you my number
Old 07-08-2016, 05:30 PM
Sounds great
Thank you vey much sir
Nick
Pm sent
Old 07-08-2016, 07:38 PM
Zman1969 Zman1969 is offline
I may be able to help with the rubber flap clips
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 07-08-2016, 07:52 PM
cook_dw's Avatar
cook_dw cook_dw is offline
What was the purpose for the rubber piece? Forcing air to go through the radiator?
Old 07-08-2016, 09:45 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: cook_dw</div><div class="ubbcode-body">What was the purpose for the rubber piece? Forcing air to go through the radiator? </div></div>
Pretty sure your right Darrell
90 Formula 350
Old 07-09-2016, 06:35 PM
ban617 ban617 is offline
Chevy 2 only has the clips &amp; rubber flap I believe.
