Old 06-24-2016, 03:56 AM
red67 red67 is offline
Default Early SBC Intake Gaskets
I'm looking for a set of early pre EGR intake manifold gaskets for a small block Chev. Specifically for the 327 in my 1967 Camaro. Attached is a a picture showing the currently available Felpro gasket with an early Victor at the top. Since the intake manifold for the 327 has no EGR provision the Felpro gasket sticks out above the manifold and does not look stock. Anybody have any ideas where I might find a pre EGR gasket? The Victor is really old and starting to flake so I really don't want to use it. It is from my inventory and probably about 40 years old. I could cut the Felpro but the steel core make the job difficult, especially for rounded corners.
Old 06-24-2016, 02:21 PM
novadude novadude is offline
Default Re: Early SBC Intake Gaskets
Don't know if you are aware of this, but those blue fel-pro gaskets sometimes don't seal very well with aluminum intakes. I would use a Fel-pro 1256. I don't think these have a steel core so they should be easy to trim.
http://www.jegs.com/i/Fel-Pro/375/1256/10002/-1
Here is a link with a scan that shows where Edelbrock says DO NOT use the blue permatorque gaskets.
http://67-72chevytrucks.com/vboard/s...d.php?t=528147
Old 06-24-2016, 04:44 PM
earntaz earntaz is offline
X2 -- works better with the silicon bead around the port ... pay attention to torque also ... TAZ [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 06-24-2016, 05:42 PM
Thanks for the comments and links on the various types of gaskets. I'm not using an aluminum intake so that is not a problem. I'm using the stock cast iron QJet intake. I'm aware of the issues with the types of gaskets for aluminum intakes as I'm a drag racer with various engines from bracket race to Competition Eliminator. I used to buy GM intake gaskets for my stock engines but now those are almost nonexistent as with other GM gaskets for older Chevys. Try buying a GM rear main seal these days. When I bought one at my local GM dealer there were only four in all of the USA and it had to come from a regional warehouse centre. Same with a timing cover gasket. Felpro has so dominated the gasket market that it is hard to buy anything else and some of their products are very poor and their tech centre help can be hit and miss. Really depends on who you get. Certainly stay away from their rear main seals. They are really bad. Not surprised that Edelbrock is making their own gaskets these days.
My concern here is the shape of the gasket. I want something that does not have the EGR provision that is like the Victor MS15114 on the top that follows the profile of the intake. The bottom gasket is Felpro 90314-1. Is this Felpro Permatorque? Doesn't say that anywhere. The head gaskets always say PT on them.
Old 06-24-2016, 06:43 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: red67</div><div class="ubbcode-body"> Felpro has so dominated the gasket market that it is hard to buy anything else and some of their products are very poor and Certainly stay away from their rear main seals..... They are really bad. Not surprised that Edelbrock is making their own gaskets these days.
</div></div>
Agree 100% here. Those blue rear main seals are garbage. Must have done a dozen rear main seals in my life and never had a single leaker until I tried one of the blue fel-pros. I am certain that it wasn't my installation technique either.
I've always preferred Victor-Reinz gaskets over Fel-pro, but they are getting harder and harder to find.
Old 06-24-2016, 09:00 PM
Thanks novadude: The blue Felpro rear main seals are actually not bad compared to the &quot;Premium&quot; (and more expensive) flouroelastomer red Felpro seal. It is the worst of the worst. Not that I would use a blue Felpro. They are pretty bad also. I did extensive research on rear main seals for my 327 rebuild I'm working on. It is for my wife's car and I don't want to hear about leaks in the driveway or in the garage. I purchased every rear main seal I could get my hands on (over $300) and compared them all. Hands down the best (not just my opinion but those in the shop) was the SKF 199. Hard to get but it is just was so much higher quality than the rest it just stood out. I found two stores locally that could get it including NAPA. I bought mine from the local independent as much cheaper than NAPA. Follow the instructions on the package to the letter when installing it. DO NOT put it in the cap or block until you have read the instructions at least a few times and understand them completely. Use the shoehorn included in the kit or you will destroy the seal with even a test installation (done that). Use anaerobic sealer from Permatex or Loctite with anaerobic activator or Kleen and Prime on the block and just enough sealer to make it work. Anaerobic sealer is way more expensive than silicone but there is just no comparison in the product but you must understand how it works and its limitations. Techs in the shop love it. Hope this might help you in the future. I can expand on my research if anyone is interested.
I also prefer Victor but as you say hard to get now with the Felpro dominance. Also, Victor seems to be concentrating on imports now that they are Victor Reinz.
Old 06-24-2016, 05:54 PM
Now I am digging back to my Corvette days -- check these gaskets out. TAZ
http://www.zip-corvette.com/57-68-28...s-correct.html
Old 06-24-2016, 08:34 PM
Thanks earntaz: Just what I was looking for. I was told that it was possible that the restoration suppliers might have something. The gasket at ZIP you linked to looks exactly like the old Victor MS15114 I have. I'll see what I can find locally and if not I'll give ZIP a call.
Old 06-24-2016, 09:22 PM
Thanks for the info on seals. Rockauto has that SKF 199 for $25.79. Pretty much inline with the Red &quot;premium&quot; fel-pro seal.
When the blue Fel-pro seal was leaking in my new Engine build, everyone said the red fel-pro seal was the one to use. Oddly, it actually worked for me - no leaks with the flouroelastomer Fel-pro seal.
I might consider picking up a SKF seal, as I expect eventually everyone else will just source seals from Fel-pro and we'll have no choice. Might be nice to get a good one while I can and keep it around for future builds.
Oh...and I agree... silicone sucks for stuff like main caps!
Old 06-24-2016, 09:25 PM
I've used various brands of gaskets over the years -- the old Victor gaskets were the cats meow before FelPro came on the market. As far as rear main seals -- it's all in preparation. I have always &quot;dressed&quot; the edge of the main cap and block where they slide into the groove on the seal. You don't want to &quot;shave&quot; and material off the seal during installation. Also, I apply a dab of Hi-Tack to the main parting surface (between cap and block) to prevent oil from seeping between them. Another &quot;trick&quot; is to off-set the seal parting lines -- I've installed them both ways ... doesn't seem to make any difference if seal is installed carefully. If available for your application -- use the one piece pan gasket. This has worked for me on both SBC and BBC engines. TAZ [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
