Old 03-29-2016, 02:07 AM
MarcDant's Avatar
MarcDant MarcDant is offline
Default Dana 60 identifacation
Can any one help decode these numbers and casting on this rear diff. I got an idea but not sure. Its complete with backing plates and 4 pin carrier. What value would this have. thanks marc.
Old 03-29-2016, 12:59 PM
Tracker1's Avatar
Tracker1 Tracker1 is online now
Default Re: Dana 60 identifacation
Can you provide the backing plate-to-backing plate width measurement please? 8 25 69 is a good sign as it is a Dana 60 for a 1970 or 1971 Dodge or Plymouth - it was assembled August 25, 1969. But 1969 assembly dates have been documented in 1971 model year cars. The width nails down whether it was put in a B body or E body.
I ain't nobody, dork.
Old 03-29-2016, 01:58 PM
RS_COPO_Canuck RS_COPO_Canuck is offline
The stamped numbers are the assembly date (sometimes there are 2) and the usage codes.
Here are the usage codes.........
Bill of Materials Numbers:
68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4
4.10 Powr-Lok 602957-5, -6
69.5-70 B body 3.54 Powr-Lok 603109-1, -2
4.10 Powr-Lok 603109-3, -5
70-72 B body 3.54 Trac-Lok 603222-1, -2
4.10 Trac-Lok 603222-3
Old 03-29-2016, 06:46 PM
I can't quite make out the number on your pic.....I see 6031xx
If it is none of the above it would be for an E-body. Here is the list including e-body.
69.5-72 B body 3.54 Powr-Lok 603109-1, -2
4.56 Powr-Lok 603109-6, -7, -8
4.56 Trac-Lok 603222-4
75-77 B body 5.13 Powr-Lok 603347-2
5.38 Powr-Lok 603347-1
69-71 E body 3.54 Powr-Lok 603080-1, -2, -4
4.10 Powr-Lok 603080-3, -5
4.56 Powr-Lok 603080-6, -7
70-72 E body 3.54 Trac-Lok 603226-1, -2
4.10 Trac-Lok 603226-4
Old 03-30-2016, 01:52 AM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RS_COPO_Canuck</div><div class="ubbcode-body">I can't quite make out the number on your pic.....I see 6031xx </div></div>
603109-2, possibly an A12 rear
Old 03-30-2016, 01:28 PM
MarcDant's Avatar
I am going to measure backing plate to backing plate, also this rear does not have a oil plug drilled and tapped into it.Thanks a bunch for the info provided.
Old 04-03-2016, 02:46 PM
MarcDant's Avatar
Thanks for all the feedback, Im now sure of year and application and when i decide to sell i can give a better description of the unit.
Old 03-30-2016, 03:09 PM
66-67 and some 68's had a drain plug on the housing.....none did after that.
Old 03-30-2016, 05:34 PM
A12pilot's Avatar
A12pilot A12pilot is offline
Yenko Advertising Member
603109-2....70-72 and up B-Body, 3.54 Powerlock. The dash number for an A12 car would have been -3 or -5, not the -2, for the 4.10 gears. Built too late to be an A12 rear, anyway. An A12 rear would have been around February or April, plus or minus a bit based on build date of the car. That's just a rough estimate, but the date on your rear is too late, and A12s only came with 4.10 gears as well. Hope that helps! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-30-2016, 07:43 PM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: A12pilot</div><div class="ubbcode-body">603109-2....70-72 and up B-Body, 3.54 Powerlock. The dash number for an A12 car would have been -3 or -5, not the -2, for the 4.10 gears. Built too late to be an A12 rear, anyway. An A12 rear would have been around February or April, plus or minus a bit based on build date of the car. That's just a rough estimate, but the date on your rear is too late, and A12s only came with 4.10 gears as well. Hope that helps! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] </div></div>
Right you are, the A12 were batch cars....forgot about that. Isn't the '71-'72 fuselage body B-bodies fitted with a wider Dana than the '70 b-body though - by a couple inches?
