Old 03-27-2016, 04:26 PM
novab novab is offline
Default 5 blade cooling fan options
Does anyone have any accurate dimensions on the factory 5 blade fans that were used on 69 and 70 big block Novas. I have a factory setup and I only have 1 5/8" between front of water pump snout to a factory 4 core radiator. Just want to make sure before I spend the money on one. Any help or recommendations on would be appreciated.
Old 03-27-2016, 04:47 PM
Default Re: 5 blade cooling fan options
I believe the fan is about 17.5 in diameter...can confirm, but that is pretty close. As for clearance between the w/p and radiator...the factory 5 blade has a 'relatively flat' profile, so you should be fine. Keep in mind there were no 'factory 4 core radiators' on the BB Nova [69-70]...only a 3 core. But, a 4 core will work, I have done it several times.
You will need the correct BB shroud and the engine has to have the correct stands/mounts for the everything to line up properly.
wilma
Old 03-27-2016, 05:08 PM
All my brackets and mounts are correct the only thing that I am not sure about is that it is a new gm crate 454, standard long pump. Would you be able to confirm the distance out from the water pump. This is the car it is going on.
Old 03-27-2016, 08:54 PM
L78steve L78steve is offline
If you use the correct Nova only fan without a spacer it will work.
I can take a picture if you like.
Old 03-27-2016, 11:11 PM
If you don't mind a pic would be great. Thanks
Old 03-29-2016, 01:14 AM
http://www.ebay.com/itm/331796037775...84.m1555.l2649
Old 03-29-2016, 02:14 AM
The radiator has been removed, but maybe this picture helps you out.
Old 03-29-2016, 06:41 AM
parkbrau's Avatar
parkbrau parkbrau is offline
Sorry, I can't measure the distance, but this should give you an idea.
Old 03-31-2016, 12:58 AM
Thanks alot. Thant looks to be what I have also.
