Old 03-10-2016, 07:03 PM
Shifted302 Shifted302 is offline
Default Fuel Pump
I was wondering, the guys running Pure Stock Drags. Are you guys running stock fuel pump's or using something inline to help the mechanical pump? Thanks for the info. I'm a newbe
You spend dollar's to go fast, I spend pennies to beat you with a 4 gear
Old 03-10-2016, 07:48 PM
L78racer L78racer is offline
Default Re: Fuel Pump
from the rules on the site: http://psmcdr.com/10.html
Fuel System
The carburetor must be correct for the year, make, and horsepower claimed. Jetting and metering changes are permitted. THE CHOKE ASSEMBLY MUST BE IN PLACE AND FUNCTIONAL! Mechanical secondary carbs cannot be substituted if vacuum operated units were original to the car. Mechanical fuel pumps must be retained. Electric fuel pumps are NOT allowed. No fuel pressure gauges are allowed anywhere along the fuel system. Factory fuel lines are required and must be correct size. No rubber lines allowed unless originally equipped as such. No fuel cells are allowed
Old 03-10-2016, 10:24 PM
Thank you, was just wondering if the fuel pumps could keep up
Old 03-11-2016, 01:14 AM
you can run an aftermarket pump as long as it looks stock. some guys running holley mech. pumps.
Old 03-11-2016, 04:47 PM
Ok, thank you [img]<<GRAEMLIN_URL>>/burnout.gif[/img]
