Old 11-01-2015, 05:45 PM
enio45 enio45 is online now
Default 15 in wheel code
friend of mine wants to switch from his 68 dog dish,14 inch wheels for his camaro with disc brakes to a 15 inch wheels with dog dish caps with disc brakes.
Anyone know what wheel code that would be for him to search for?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-01-2015, 07:01 PM
69VN's Avatar
69VN 69VN is offline
Default Re: 15 in wheel code
According to Alan Colvin's Chevrolet by The Numbers 1965-69...Assuming the car is a '68
-The wheel application is as follows...
*15x6 Passenger, taxi & police wheel code is XT
Sal [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 11-01-2015, 07:48 PM
scuncio's Avatar
scuncio scuncio is online now
Pretty sure YZ is the code he needs. This is a '69 big car disc brake application. If he doesn't care about codes, there are a lot of mid-late 1970s wheels that will work.
Old 11-01-2015, 08:23 PM
Day2_69Z Day2_69Z is offline
Those 15x6 67-68 style HD Police,Station Wagon wheels are Mostly if not all....are Riveted &amp; carry the identical Dimensions as AD Z/28 Wheels.
Just helping
Old 11-01-2015, 09:28 PM
x77-69z28's Avatar
I thought XT's were 14x7?
Old 11-01-2015, 09:57 PM
Jonesy's Avatar
Jonesy Jonesy is offline
XT's are 14x7. The above reference is not a good one. [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 11-01-2015, 10:24 PM
69VN's Avatar
Old 11-01-2015, 10:42 PM
DW31S's Avatar
DW31S DW31S is offline
What do the &quot;J&quot;, &quot;JJ&quot;, &quot;JK&quot; codes designate?
Old 11-01-2015, 10:51 PM
aawtech aawtech is offline
As an Impala guy (owned many 68 SS427 disc brake cars), I can tell you 100% that there is no 15 inch wheel that will clear the 68 4 piston calipers other than the DC Rally wheels. The guys who are running stamped steel wheels on 67-68 cars are running Corvette rotors and doing some non-stock modification to run them. If you are interested, drop a note over at Impallss427.com and ask what they are doing. The 68 and 69 15x6 stamped wheels were only available one drum brake or later single piston caliper applications. Those 4 piston calipers are massive and the 15 inch steel wheels will not mount on the hub/rotor assembly without rubbing. That is why you find black painted DC wheels on several disk brake full size cars. They had full wheel covers on them and that was the only wheel that would clear the 4 piston deal.
Donny
Old 11-03-2015, 02:47 AM
interesting info above.....what to do? so no 15 inch wheel will clear the brake caliper...and yes, he has the double piston one on the car.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
