Old 07-21-2015, 02:23 AM
Default 1182 crank purchase
Just received an 1182 crank that was advertised as std. std. The rods are std, and look perfect. Mains have been ground .010, but they also still look perfect, and it is apparent the crank was run after it was ground.
I can return it, but have to pay return shipping. I haven't seen a std. std. (other than the one in my current LT 1) in a while, so am contemplating keeping this one.
My only concern is that the factory "Tufftride" heat treatment has been removed. I know it is still a forged crank, and frankly, believe the heat treating is probably more important on the rods than the mains.
This is going in a high winding long rod (6&quot 350 that will see 7500 rpm. Would you run it, or hold out for a std. std. crank (if I can find one).
Old 07-21-2015, 03:06 AM
VintageMusclecar's Avatar
Default Re: 1182 crank purchase
Sucks you didn't receive what you thought you were getting. [img]<<GRAEMLIN_URL>>/frown.gif[/img]
That said, if it passes mag, balance it and run it.
Old 07-21-2015, 03:12 AM
scuncio's Avatar
scuncio scuncio is online now
Tufftride heat treatment should have no measurable effect on strength, but the wear resistance won't be quite as robust. I would not think twice about running it.
Old 07-21-2015, 03:41 AM
ss427copo's Avatar
ss427copo ss427copo is offline
I'd run it and not look back.
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 07-21-2015, 03:53 AM
L78steve L78steve is offline
1182's are still easy to find in NOS. I just got one on Ebay never run in the box for $500. Another guy has 3 in Hickory NC. listed on Ebay.These are the Tufftride versions.
Old 07-21-2015, 03:59 AM
http://www.ebay.com/itm/231590881314...%3AMEBIDX%3AIT
Old 07-21-2015, 04:01 AM
http://www.ebay.com/itm/New-SBC-350-Forg...9bb&amp;vxp=mtr
Old 07-21-2015, 04:42 AM
For ~$650-ish you can get into a decent aftermarket 4340 crank (not needed here, just for comparisons sake)
Lynn, if it makes you feel any better, nearly 30 years ago I had a <span style="font-weight: bold"><span style="text-decoration: underline">cast</span></span> crank in a 355 in my daily driver `75 Monza. I turned that thing 7500+ nearly on a daily basis, and it lasted ~2 years before a piston finally succumbed to detonation and cracked off a top ring land.
The crank was still perfect and went back into service in another engine.
Man...those were the days...
Old 07-21-2015, 03:51 PM
Considering what I paid (less than $300), I definitely did OK on this.
Will run it as is after a mag and polish, having the whole assy balanced.
Old 07-22-2015, 03:15 PM
miket1 miket1 is offline
A friend of mine has been drag racing 30 years or more, he said he turns down the crank in his drag race car .020/.020 to get less rotating area, less drag resistance.
69 Z28 Burgandy
