Old 06-19-2015, 05:00 PM
SeattleCarGuy SeattleCarGuy is offline
Default Front coil spring compressor???
Hi all,
What is your favorite, easiest to use, front coil spring compressor and where can I order one?
Thanks in advance,
Paul
Paul
'62 Bel Air 409/409
'63 Impala SS 409/340 convertible
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 06-19-2015, 09:11 PM
bugsy bugsy is offline
Default Re: Front coil spring compressor???
Snap-on. They are one of the best. The ones made in china break. Sd the money on real steel not cast.Good luck.
Old 06-22-2015, 10:04 PM
Supergas990 Supergas990 is offline
I've got a Matco/Macpherson. Works slick and you can run it with an impact.
Blair
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
1968 L79 Corvette Convertible (son's)
Old 06-22-2015, 10:18 PM
I've been using this KD compressor for years. DO NOT use an impact on it though.
I add the mole Skin to the hooks to prevent scuffing the coils.
Old 06-22-2015, 11:45 PM
I was expecting someone to say floor jack. I guess I am the only one who exclusively uses a floor jack under the lower control arm to compress / decompress a spring. I realize if you have a first gen Nova or first few gens of Mustang, this won't work. But on the other GM cars with the coil sitting in the lower A arm, I just use a floor jack. Then I don't have to worry about how to get the darn spring compressor out through the shock hole.
Old 06-23-2015, 01:12 AM
Lynn
How's that work out for you when there is no engine in the car... [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
I use the same one Verne show's a picture off, I glued thin neoprene rubber strips to the jaws to help from slipping.
Mike
Old 06-23-2015, 02:10 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">Lynn
Mike </div></div>
Even with the compressor, I still used a floor jack because of no engine in the car. I have a complete photo step by step of how I did it, but the files are too big I guess and won't post. I ran straps under the floor jack and attached to the frame so when the jack lifted the lower control arm, it couldn't lift the frame. IT was tedious to set up but in the long run everything was a breeze to put back together. I wish I could post the photos.
Old 06-23-2015, 01:31 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Verne_Frantz</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">Lynn
Mike </div></div>
Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] </div></div>
Verne -- I've used then same method and it works well ... just be cautious! TAZ
Old 06-23-2015, 04:36 AM
Mike </div></div>
Not worth a darn Mike. Therein lies the problem with my method. When I put the springs in my car, I had a few family members standing on the sub frame.
Old 06-23-2015, 02:29 PM
Billohio Billohio is offline
Lynn we need pictures!!
Bill
