Old 06-02-2015, 10:08 PM
Default Ansen Sprint 14x7 rims with Chev bolt pattern
Looking for a pair of 14x7 Ansen Sprint rims in excellent condition as long as they clear the front dics brakes on a 69 Camaro, if not I won't need'm...if they do...
Must be the version with the 5-ear center caps and have the standard Chevy 5 x 4-3/4 bolt pattern. Ideally these would already be polished.
Thanks again guys...
Along with that, I'd also be looking for F70-14 Goodyear Poly's.
Old 06-03-2015, 02:12 AM
Day2_69Z Day2_69Z is offline
Default Re: Ansen Sprint 14x7 rims with Chev bolt pattern
Is this a change to lower the front even further or additions to your next build stash ?
Old 06-03-2015, 03:46 AM
...still working on front tire clearance issues on the COPO...15x7 with F70-15s are just a tad too big, the F60-15s have more clearance issues cause they are too fat...can't find a Goodyear Poly with RWL in 15" that fits well enough on the 15x7 Sprints...need the width of the F70-15 but the height of the F60-15...so it looks like my best option is the 14x7 with the F70-14s...I'm tempted on the E70-15s but they are not much smaller than the F70s...was thinking about the 775/15s but then I need to come up with 15x5.5 or 15x6 Sprints...I'm open to opinions too...ugh...
Old 06-03-2015, 04:48 AM
GTO_DON GTO_DON is offline
I will look tomorrow. I have 14x7 sprints and have f70 tires. I probably have the right 15's for you too.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 06-03-2015, 04:46 AM
I feel for you....as I am/was in the same situation.
That's why I used the aluminum slots up front with a tad over 3"" of BS....instead of the stock 4 1/4" you have with a 15" Rally wheel.
I have a pair of Fentons in 14 x 7 that have 3- 3 1/4 BS but these wheels are pitted.....deep enough that the face will need cut on a lathe. . ...with no guarantee even that will remove the pits.
I hate to scrap them, but even the cheapskates won't buy them for a rat rod.....
I can't see spending $$ on them or attempting to cut them down.....jmo.
The wheels I used kicked the tires out enough to clear the inner fender at the rear, the front inners have no issue.
A G70 14 maybe, but I'd use the F70 14 .....
Or. the F70 15 on a closer to stock BS Fenton (if they even made the size)
Old 10-09-2015, 01:19 AM
...BUMP...
