Old 04-03-2015, 07:50 PM
Furback Furback is offline
Default L78 Dyno
I finished assembling my NOS L78 shortblock today. Put a pair of 69 840 heads on it and a 163 intake. The cam is original specs and solid. 3/8 pushrods and Crane race rockers. So other than the rockers the engine is exactly as an original would be. Standard everything. Also installed hardened valve seats and manley stainless valves. Comp cams springs. Should be dynode within a week. It will be interesting to see what kind of numbers the dyno sessions show.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
Old 04-03-2015, 08:05 PM
L78 Fred L78 Fred is offline
Default Re: L78 Dyno
Let me know the numbers
I will be doing the same in the next 2 months
Fred
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block -272 casting
Always looking for dated L78 396 & L72 427 components from Jan-Apr 69
NOS or pristine 69 Red Standard & Orange Deluxe interior pieces
USN 1992-2019
Master Chief-Seabee Diver
Equine Immersion Foundation Board Director (Fundraising)
Assisting our Nation's Finest Tier One Warriors with PTS & readjustment
A 501 3C Non-Profit Foundation
Old 04-04-2015, 02:59 PM
hardened valve seats really necessary?
Old 04-04-2015, 03:47 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">hardened valve seats really necessary?</div></div>
It's a toss up -- I've read pros/cons. If you will be running the livin' hell out of the motor for extended period of times -- hardened seats are a must. But if you're just cruzin' with occasional jumping on it you probably don't need to install.
Valved seats back in the day were induction hardened -- but if the valve seats are ground below this &quot;hardened surface&quot; erosion may occur.
I'm sure others will chime in on this ...
TAZ
Old 04-04-2015, 04:51 PM
doubt if either of these guys are going to run their car that hard. both will probably use a lead additive or some racing gas anyway. Don't like cutting into stuff that can cause problems later. Not necessary just like floating wrist pins arn't really necessary for street motors IMO.
Old 04-04-2015, 05:28 PM
JRSully JRSully is offline
I put hardened seats in my 70 291 heads on the 70 L78, didn't want to deal with lousy gas issues and the engine gets hammered on regularly. My engine dyno'd at about 428hp at 5600 rpm, dead stock except roller rockers, pertronix and headers, orig intake, compression, 4557 holley, stock heads, nos 143 cam. You need somebody experienced to do the valve seats right, have to watch the water jackets
71 Porsche 911 Targa
Old 04-14-2015, 05:21 AM
Kurt S Kurt S is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">hardened valve seats really necessary? </div></div>
If it sees a sustained hi-output duty cycle. That would be a tow vehicle where it's running high temps for long periods of time.
Not for a street or race car.
Kurt S - CRG
Old 04-04-2015, 11:38 PM
Jim -- what did you do for valve springs? Stock LS-6?
TAZ
Old 04-05-2015, 03:30 PM
Taz, I believe I used a very close to stock, dual valve spring. Consulted with Crane (roller rockers) and my engine builder, but I know they are very close to stock. All the hp is in by 6000-6500 on a stock L78 anyway, no need to rev it any higher than that, just asking for trouble. Roller rockers are the ticket on these engines (unless you need to have stock valve covers, but you can use a camouflage spacer)they really let the engine rev and are very durable. Valve train is the weak link on these engines. But mine (with this set up) has been bulletproof and I have adjusted the cam only twice in 6 or so years
Old 04-05-2015, 04:50 PM
Copy that -- I agree with going crazy with valve spring pressure may cause hate a discontent ... just looking for trouble on a 95% street machice. I have roller rockers ...
Thanks -- TAZ
