Old 03-23-2015, 01:06 AM
1968 nova ss 1968 nova ss is offline
Default 4 pistons caliper brakes/pad installions
Hey guys my 68 nova ss 396 was optioned with the 4 pistons calipers.just installed new wheel bearings...any easy way to reinstall the brake pads..as each pistons is pulled back the other 3 move inward...the only way I see to reinstall brake pads is to disconnect the rubber brake hose where it mounts at the frame,plug the line so all 4 caliper pistons get be pushed inward... any help out there guys is appreciated.thanks.Chris
Old 03-23-2015, 01:25 AM
PxTx's Avatar
PxTx PxTx is offline
Default Re: 4 pistons caliper brakes/pad installions
Can you just open the bleeder and push the pistons back?
Paul III
Old 03-23-2015, 01:52 AM
Guest
Posts: n/a
Use a small screw clamp (s) and pull all the pistons back as far as they will go all at once. They won't move back as long as you don't touch the brake petal.
Old 03-23-2015, 01:50 AM
chevyman0429's Avatar
Why not open the lid on the master cylinder and gently push back both pistons at the same time. Then do the other side the same way.
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Old 03-23-2015, 02:26 AM
earntaz earntaz is offline
Here is how it is done on Vette' 4 piston setups. TAZ
http://www.corvettemagazine.com/tech...-installation/
Old 03-23-2015, 03:26 AM
good ideas so far..with the 4 pistons .simply isn't enough room to install small clamps and open up calipers and install pads...if I an not mistaken,each pistons has a small spring behind each piston,releasing bleeder valve will help ,but doesn't allow the pistons to go far enough back to install pads..will continue to install tomorrow.chris
Old 03-23-2015, 05:06 PM
Chris -- check this out ... TAZ
http://www.zip-corvette.com/catalog/prod...tallation-tool/
Old 03-24-2015, 02:22 AM
it seem Napa makes to tool to help in spreading the caliper pistons ,especially easier for 4 piston calipers brakes ,part no SER279,hoping to purchase it tomorrow and we will see what happens.Chris
Old 03-24-2015, 03:15 PM
jasonL78 jasonL78 is offline
I did 2 68 Novas with the 4 piston disk brakes I don't recall having an issue Chris. Hope it all works out for ya.
Looking for the next project.
Old 03-26-2015, 03:00 AM
well,i ended up finding a piece of brake line with fitting attached,removed the brake bleeder screw and attached the line.pushed in the calipers in by hand while installing the brake pads at the same time and just let the brake fluid from the line attached drain into a old coffee can...it took some effort,but none the less,it worked..Chris
