Old 02-09-2015, 10:10 PM
iluv69s iluv69s is offline
Default 60 vette motor and trans id/value?
recentky saw this motor and trans that was pulled from a running corvette that is being converted to make a street rod.
block cast number 3859532 cast date is C59...looks like CE on the pad alond w other numbers(hard to see)... did they make CE's back then? also has cast intake 3746829 dated j (or i) 9 9 and original looking carb, power pack heads, correct exhaust,generator brackets, engine mount,etc.
trans has 11 23 59 on tail ...and T10-1B W.G.DIV. and looks like A (or 4)-12 below ....has hurst shifter body.. is that correct? looks like correct pull up handle, etc? looks like oroginal stlye bell housing also...did they put VINs somewhere on the trans?
this car ran and drove real nice when engine/trans recently pulled.
any ideas on ID, value? thanks SYC
Old 02-09-2015, 10:36 PM
Furback Furback is offline
Default Re: 60 vette motor and trans id/value?
Intake
1958-61
3746829 283 4 iron WCFB, B Y/230hp
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
Old 02-11-2015, 04:23 PM
Fast67VelleN2O's Avatar
Transmission will not have a vin number on it. Hurst shifter is not correct. Pull up handle is aftermarket if it's a Hurst body. Bell housing should be an aluminum open bottom 591.
Day 2 is Life.
Old 02-12-2015, 03:56 PM
thanks guys.... the bell is open aluminum design... not sure the number though....
any idea on value on the trans/bell..w wrong shifter I assume. ...
the motor may be worth most as parts I guess.
Old 02-13-2015, 02:34 PM
NCGuy68 NCGuy68 is offline
@iluv69s
What is the casting number on the tranny main case?
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
