Old 01-07-2015, 07:17 PM
Fast67VelleN2O's Avatar
Default Air Cleaner Base ID help
Scratching my head on this one. For a Rochester Q-Jet. 12-3/4" in diameter.
Day 2 is Life.
Old 01-07-2015, 07:28 PM
Default Re: Air Cleaner Base ID help
Is that possible that piece was spot welded into a larger base?
Old 01-07-2015, 07:33 PM
novadude novadude is offline
Weird. I can't figure out what that would be from? Mid-70s vette or something with cold air hood? I thought they were always built on a dual snorkel base with the ~12.75" element though.
Old 01-07-2015, 07:47 PM
Although there is a few drilled holes around the perimeter, there is no evidence of spot welds ever being anywhere. The drilled holes aren't uniform so who knows why someone was screwing around with it.
Day 2 is Life.
Old 01-07-2015, 08:41 PM
hiperf69 hiperf69 is offline
Yenko Advertising Member
I'm thinking '67 Olds
Closed element maybe!
Old 01-07-2015, 09:30 PM
It's not a Star Wars base (I checked already) and this isn't for Climatic Combustion Control.
Day 2 is Life.
Old 01-07-2015, 10:07 PM
Now looking at it on my I-pad instead of my phone I see that the outer lip
is pointing down. is that Correct?
Very strange with the two flats positioned up in the front.
Old 01-08-2015, 04:09 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: hiperf69</div><div class="ubbcode-body">Now looking at it on my I-pad instead of my phone I see that the outer lip
</div></div>
Outer lip is pointing down for sure.
Day 2 is Life.
Old 01-08-2015, 04:17 AM
markjohnson's Avatar
Would that be used for the 1968-69 327 &amp; 350 Corvettes that had the Q-Jets and open element air cleaners?
Old 01-08-2015, 04:08 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: markjohnson</div><div class="ubbcode-body">Would that be used for the 1968-69 327 &amp; 350 Corvettes that had the Q-Jets and open element air cleaners? </div></div>
No, that air cleaner base is much larger in diameter and has a breather tube.
Day 2 is Life.
