Old 05-25-2014, 01:36 AM
Default Aftermarket temp gauge sender. Where?
Putting some vintage SW gauges in my 69 Z. I want to keep the idiot lights.
I can put a sender in the intake manifold right by the Tstat. I am thinking it would look a little cleaner to put it in the pass side cylinder head almost out of sight.
What do you guys do when installing aftermarket temp gauge?
Old 05-25-2014, 02:30 PM
69VN's Avatar
69VN 69VN is offline
Default Re: Aftermarket temp gauge sender. Where?
All depends on personal preference. I like the idea of placing it in the cylinder head---kinda outta sight outta mind. But I've also had it upfront in the intake manifold in previous cars. You may or may not get a more accurate temperature reading here.
Sal
