Old 05-24-2014, 06:33 PM
resto4u resto4u is offline
Default Attention 1970 nova owners
I have the opportunity to manufacture the turbo 400 trans kickdown switch bracket. This bracket bolts to the firewall. This is a one year only part for nova's with the turbo 400 trans. The bracket will be an exact match, except it will come in bare steel instead of grey phosphate plating. Right now i am just trying to see if there is enough interest to put this part into production. There is expensive tooling that would have to be done to duplicate this bracket. I need to have a minimum order of 20 pcs. or more to make this feasible. This would be a pre-sale/ made to order. The price would be $99 each. So right now i just need feedback from people who would actually purchase this bracket. Thanks,Roger
Old 05-25-2014, 11:59 AM
parkbrau's Avatar
parkbrau parkbrau is offline
Default Re: Attention 1970 nova owners
Good luck. I finally found my Idle solenoid switch bracket. THese things are harder to find then hens teeth.
Old 05-25-2014, 12:40 PM
bbbenny bbbenny is offline
Roger, Your work is perfect, in every way. Congrats, hope you clean house. If only other manufactures, would DO the same thing. BBBenny [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 05-27-2014, 03:18 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: resto4u</div><div class="ubbcode-body">I have the opportunity to manufacture the turbo 400 trans kickdown switch bracket. This bracket bolts to the firewall. This is a one year only part for nova's with the turbo 400 trans. The bracket will be an exact match, except it will come in bare steel instead of grey phosphate plating. Right now i am just trying to see if there is enough interest to put this part into production. There is expensive tooling that would have to be done to duplicate this bracket. I need to have a minimum order of 20 pcs. or more to make this feasible. This would be a pre-sale/ made to order. The price would be $99 each. So right now i just need feedback from people who would actually purchase this bracket. Thanks,Roger </div></div>
Are you talking about the bracket that holds the kickdown switch near the gas pedal?? Can you post a photo???
thanks..wilma
Old 05-27-2014, 11:41 PM
yes that is the bracket. it holds the trans kickdown switch.
Old 05-29-2014, 12:28 AM
Old 06-05-2014, 04:53 AM
nuts4novas nuts4novas is offline
Switch should be mounted on the other side of the bracket.
Old 08-14-2017, 08:18 PM
earntaz earntaz is offline
Does anyone have a image of this bracket mounted on the firewall next to throttle linkage? TAZ
Old 08-31-2017, 12:18 AM
Wilma (Tom) has stepped up AGAIN!! THANKS!!!!
Now all I need is a throttle pedal assembly with a straight arm, not curved ... or I may have to make one ... TAZ
Old 06-01-2014, 02:28 AM
In the last image -- is the switch mounted on the correct side of the bracket?
