Old 03-26-2014, 03:53 AM
MosportGreen66's Avatar
Default Wanted: Distributor and Oil Pan
Hi Gang, looking for a 1111488 distributor (may, 1 1969 build) and an oil pan for an SS350 4spd.
[email protected]
Old 03-27-2014, 12:37 AM
GTO_DON GTO_DON is offline
Default Re: Wanted: Distributor and Oil Pan
I think I have the oil pan. How do I know if it's the one.
1969 GTO convert RAM AIR 4spd
1964 GTO convert survivor
Old 03-27-2014, 01:16 AM
jl8z28 jl8z28 is offline
Yenko Premier Member
I have a oil pan It is off of a Camaro How can I tell if it is the one you need
Old 03-27-2014, 01:18 AM
Look here:
http://www.camaros.net/forums/showth...28+oil+pan+nos
Even though that is a comparison of the Z/28 pan, the external stamping will be the same. The 350 SS pan just has a built in baffle instead of a bolt on windage tray.
Look for the deep draws on the pan as shown on the orange pan in the comparison.
Old 03-27-2014, 10:14 PM
69VN's Avatar
69VN 69VN is offline
Dan if you need a used original GM oil dipstick tube for your engine PM me. Have pics.
SAL
Old 04-02-2014, 02:37 AM
Found both, thanks guys!
