Old 03-01-2014, 02:52 PM
70 copo 70 copo is offline
Default Water Pump Re-builders here at SYC?
I am rebuilding the HB 350 out of my 69 Z-11 and I am doing some mild performance mods to the engine while maintaining a stock exterior appearance. Here is the question...is there anyone here who rebuilds water pumps?
I would like the rebuild to incorporate a hi flow impeller. Thanks! [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 03-01-2014, 09:27 PM
Default Re: Water Pump Re-builders here at SYC?
Phil
I don't know of anyone here. I and others have good luck with Arthur Gould, fast turn time.
Mike
Water pump
Old 03-02-2014, 04:35 AM
x77-69z28's Avatar
X2 on Arthur Gould. Good bunch of guys work there. They did a nice job on my small block pump.
Old 03-02-2014, 05:21 AM
Billohio Billohio is online now
Arthur Gould is the place.
Bill
Old 03-02-2014, 05:46 AM
YENKO DEUCE REGISTRY's Avatar
Another vote for Gould.
Marlin
Old 03-02-2014, 12:37 PM
69 Post Sedan's Avatar
Had mine sent out and rebuilt by Arthur and it works great.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-02-2014, 01:29 PM
The original 300 HP engine in its stock configuration was pretty tired so I decided 45 years was enough and tore it down. Tired was an understatement. Original cast Nodular Iron crank was pretty much shot and not worth the machine work to repair. The stock pistons and rods were OK but the block needed to be bored .030. Valves/guides in the original heads were shot and to top it off the intake had a chunk of carbon in the underside tray the size of your fist that was cooking the Q-Jet. In other words the typical SB that has been cruised to death for better than 4 decades.
The question was to do a stock rebuild or a performance rebuild. Since I drive the car the answer was obvious. The engine will look 100% stock from all external appearances,- except at idle I think.
1969 HB 350 with TH-350 Tranny.
Pistons 1969 Stock style with Valve reliefs-Keith Black Hypereutectic .030 Pistons.
Eagle I beam Forged rods (Floated)
Original 186 heads converted from 1.94 to 2.02 valves.
1182 LT-1 Steel crank
L-79 cam and lifters
Comp Cams Roller Rockers
21 inch radiator-- original Harrison tanks on a custom 4 core 21 inch middle
Hughes 2000 Stall converter for the TH-350
and now the 692 water pump - with a Hi flow impeller.
Thanks gents... Mr.Gould it is. [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Here is the Radiator modification...Just a tad bit wider.
Old 03-02-2014, 02:04 PM
396L35's Avatar
396L35 396L35 is offline
Arthur Gould is my pick as well.
Mark
Old 03-02-2014, 02:14 PM
Gould is good.
Old 03-03-2014, 02:09 AM
MosportGreen66's Avatar
Us Corvette folk use Bill Mock and his work is fantastic
