Old 02-25-2014, 12:32 PM
Default Scanners
Definitely technical, not restoration.
I have put this off as long as I can. Getting too many late model cars in the family, and would like to be able to read codes without leaving the driveway. I had a Cadillac DTS for a while and was spoiled by the self diagnosis.
I noticed some of the really cheap ones don't read Toyota. We still have one Toyota in the family (other one was rear ended last week). I was looking at this one on ebay:
http://www.ebay.com/itm/191000099107...84.m1423.l2649
Must be able to read Ford, BMW, Toyota, Infiniti.
Any comments? Suggestions? What are you guys using?
Old 02-25-2014, 01:19 PM
PxTx's Avatar
PxTx PxTx is offline
Default Re: Scanners
http://www.scantool.net/scan-tools/obdlink-mx.html
I like this concept, though metting your requirments could get expensive.
Paul III
Old 02-25-2014, 04:35 PM
Trying to keep it under 50 bucks.
Old 02-25-2014, 04:46 PM
earntaz earntaz is offline
Make sure it is "reprogrammable" just in case you get a newer vehicle ...
Old 02-25-2014, 07:48 PM
As long as it works on anything made today, I am probably good to go.
I rarely buy anything less than 10 year old. Yeah, I am that cheap.
Old 02-25-2014, 08:19 PM
PxTx's Avatar
I can't imagine anything in the $50 range offering anything more than it's competitors. I used a similar one from Autozone and it is adequate for basic obdii stuff. Found which O2 sensor was bad on the Yukon. Could have probably just used my eyes and saw the harness rubbing the drive shaft though. Interface is laggy and navigation is basic but acceptable.
Paul III
Old 02-25-2014, 08:33 PM
dvss1 dvss1 is offline
You will have to watch out as some of the cheaper scanners don't show live data of the vehicle running. Anything newer than 1996 you will need a OBD2 scanner. This will work on any vechile no matter what make or model.
Old 02-26-2014, 12:47 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dvss1</div><div class="ubbcode-body">You will have to watch out as some of the cheaper scanners don't show live data of the vehicle running. Anything newer than 1996 you will need a OBD2 scanner. This will work on any vechile no matter what make or model. </div></div>
You would think. But some of the cheap scanners, even for OBDII, clearly state they will not scan a Toyota. Not sure why.
I am going to go ahead and pull the trigger on the one I linked to. Will report back. Since I posted, we added a GM car. Just bought a 2003 Buick Century loaded with 33,000 miles (92 year old lady driver) for my son to transport the twin grandsons. I can't believe it, the little buggers turned one year old already. They are so fun.
Thanks for the suggestions.
Old 02-26-2014, 04:42 AM
parkbrau's Avatar
parkbrau parkbrau is offline
Or why not just use Auto Zones?
Old 02-26-2014, 12:50 PM
Like I said in the first post, would like to be able to read codes without leaving the driveway.
