Old 12-17-2013, 03:16 PM
Default Any Mopar A-833 4 Speed Gurus? 18 Spline Aluminum
I have not had much experience with A-833 transmissions. I got this in on trade the other day and am trying to figure out what it is.
From the little amount I know about these it looks to have an A-body tailhousing and has the stronger 440/Hemi 18 spline input shaft/gears. The part that puzzles me is it is all aluminum. Does anyone know anything about these? Is it an aftermarket piece, factory race unit, a converted late model overdrive tranny, or something else entirely?
Sorry for the poor picture quality. I snapped the shot early this morning and it was freezing outside, well California freezing.
Old 12-17-2013, 05:07 PM
njsteve's Avatar
njsteve njsteve is offline
Default Re: Any Mopar A-833 4 Speed Gurus? 18 Spline Aluminum
1968 Super Stock Hemi Dart and Barracuda.
Old 12-17-2013, 05:22 PM
Ummmmm....WOW. Thanks Steve. Is there any way to prove that with casting numbers, etc? A member on the moparts site said it was a Direct Connection catalog part. I don't want to misrepresent it. I thought the Direct Connection cases came steel bushed for the cluster pin which this one does not appear to be. I think I remember you posting that you owned a 68 Hemi Dart so I imagine you have much more knowledge than most on the subject.
Old 12-17-2013, 06:04 PM
This basket case trans also came with the deal. It also appears to be an early aluminum A-833. This one has the trunion output. Interesting stuff, I just don't know much about it.
Thanks again,
Old 12-17-2013, 08:19 PM
Fast67VelleN2O's Avatar
Experimental part number on the b body case?
Day 2 is Life.
Old 12-17-2013, 08:35 PM
PxTx's Avatar
PxTx PxTx is offline
Only 833 aluminum box I ever had was from the 1970's and ended up being an economy 3 speed with overdrive if I recall correctly.
i think the front collar was larger than the iron cases.
Paul III
Old 12-17-2013, 09:34 PM
marxjunk marxjunk is offline
ive seen a few..the ones i know of where direct connection over the counter stuff...ive seen 3...2 18 spline one normal..
buy a galen govier book..it decodes even the D C stuff
Mark
Old 12-18-2013, 10:27 AM
njsteve's Avatar
The Direct Connection case was modeled after the Super Stock piece. It's been a long time and I don't think I have any photos of the tranny that came with my car (which actually turned out to be Dick Landy's four speed car).
You might want to try asking on moparts.com. Someone there should be able to chime in.
Old 12-18-2013, 12:04 PM
Keith Seymore's Avatar
Here's a pretty nice link on the A833, although I recall it is specific to the overdrive version.
http://www.customclassictrucks.com/t..._transmission/
That particular trans came stock in my '87 Chevy pickup (aluminum case).
K
'63 LeMans Convertible
'63 Grand Prix
Old 12-18-2013, 12:22 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Definitely DC - race or catalog trans
