Old 12-10-2013, 06:08 PM
BillD BillD is offline
Default Plastic gauge face scratch removal
The plastic dash board gauge lens on my 66 Chevelle is scratched and dirty. Is it possible to polish out the scratches as a "Do It Yourself" operation? Or is this better left to a professional?
If you do it at home are there any suggestions? If it is better left to a professional any suggestions as to who?
Thanks in advance for any help.
Old 12-10-2013, 06:15 PM
Default Re: Plastic gauge face scratch removal
I believe Eastwood sells a plastic polishing kit for the lens, but usually buy a new one. They're well made and cheap, but you do have to have the dash apart.
http://www.ss396.com/mm5/merchant.mvc?Sc...Code=DASHLENSES
69 El Camino
69 Nova
C7 Vette
Old 12-10-2013, 06:26 PM
68l30's Avatar
68l30 68l30 is offline
I've had really good results with 3M's Pink Fill in Glaze and have also used Wenol metal polish. Start in a small corner first, as a precaution, but I'd swear by both. Bill is correct, I'd pull the cluster so you can do both sides of the lens. You'd be surprised how cloudy the inside gets.
BIG
Old 12-10-2013, 06:33 PM
Stay away from car wax.It's a quick fix and won't hold up over time.
I use NOVUS on everything plastic.
https://www.youtube.com/watch?v=9qvGnFecVDs
Fast forward to the 5:10 mark for the demonstration.
Old 12-10-2013, 06:40 PM
DRCBOWTIE DRCBOWTIE is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">Stay away from car wax.It's a quick fix and won't hold up over time.
Fast forward to the 5:10 mark for the demonstration. </div></div>
Agreed, this stuff works excellent. Easy to find at a local motorcycle dealer.
Old 12-11-2013, 12:19 AM
Thank you for the help. I will order polish and try to clean up the lens.
Old 12-11-2013, 03:23 AM
I have used Mequiers plastic polish with good luck, Used this polish on my 69 Camaro lenses.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 12-12-2013, 01:57 AM
larry_csa larry_csa is offline
try tooth paste. I use it a lot on my glasses. it gets out small scratches and polshes.
Larry
Old 12-12-2013, 04:43 PM
I have used 2000 grit sand paper under the faucet and removed some pretty deep scratches from plastic faces, if you end up having to do this you will have to go to a compound then to polish and then plastic polish. Same technique as removing the scratches and oxidation from Head lamps however the gauge plastic is softer.
Old 12-12-2013, 07:11 PM
XXXGoldL34M20's Avatar
I used a pinball playfield and plastic cleaner, designed to clean plastic parts and the surface area of a pinball machine, it also works well on plastic lenses on the cars.
