Old 09-16-2013, 08:33 PM
mockingbird812's Avatar
Default M21 Oil Weight/Brand Recommendation
Tried our search... no joy. Sorry, as I am sure this has been discussed. This is for a 70 442.
Thanks!
Sam...
Old 09-16-2013, 09:06 PM
TDW TDW is offline
Default Re: M21 Oil Weight/Brand Recommendation
Sam, I did some research on this a while back. What I found and use in all my Muncies is Pennzoil Gearplus SAE 80W-90W GL4. The GL4 works best with the brass syncros.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-16-2013, 09:38 PM
good choice Tony.
Old 09-16-2013, 11:33 PM
Thanks guys!
Sam...
Old 09-17-2013, 02:46 AM
VintageMusclecar's Avatar
I'm using CRC GL-4 as directed by the man who built the Muncie in my Chevelle.
Link
Old 09-17-2013, 10:48 PM
napa68's Avatar
napa68 napa68 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">I'm using CRC GL-4 as directed by the man who built the Muncie in my Chevelle.
Link </div></div>
My guy here in WI, same recommendation as well for my M22W.
Old 09-17-2013, 01:32 PM
smoke' em II's Avatar
smoke' em II smoke' em II is offline
[img:left][/img]
ACES #08588
OCA #28054
1970 Chevelle SS
1970 Olds 442 Survivor
1997 SVT Cobra convertible
Old 09-17-2013, 03:36 PM
I like pixtures!!!!!!!!!! [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Sam...
Old 09-17-2013, 03:42 PM
novadude novadude is offline
Sta-lube stuff above is what is in mine. Works fine. I think I got it through Amazon.com, but I know NAPA stores carry it as well. My local store didn't have the qt size, so I just mail ordered.
Old 09-17-2013, 04:01 PM
Hemicolt Hemicolt is offline
Royal Purple:
Synchromax – Manual Transmission Fluid
Synchromax is a manual transmission fluid that increases performance and the life of your equipment. It improves shifting, reduces gear noise and increases power transfer to the wheels. It also lowers operating temperatures and provides outstanding wear protection for longer transmission life.
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid. It’s also ideal for 4×4 transfer cases and motorcycle gear boxes. Synchromax is fully compatible with all types of friction materials. It provides excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers.
Synchromax is formulated with Royal Purple’s proprietary Synerlec technology for unsurpassed performance and protection.
Max Gear – High Performance Gear Oil
Max Gear is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe
Max Gear is an ultra-tough, high performance automotive gear oil designed to provide maximum protection to heavily loaded gears while maximizing power throughout the drive train. Max Gear outperforms ordinary gear oils by combining the highest quality synthetic oils with Royal Purple’s proprietary Synerlec additive technology. Max Gear makes gears run smoother, quieter, cooler and longer without overhauls. Max Gear is formulated with a friction modifier additive – no additional additives are necessary.
Max Gear is available in the following viscosities: 75W-90, 75W-140, 80W-90, 85W-140 and SAE 90
It's not the critic that counts, not the man who points out how the strong man stumbled or whether the doer of deeds could have done them better...
