Old 09-11-2013, 06:40 PM
twertsy twertsy is offline
Default For the Bodymen
How the heck do you get the metal scrap out of a spot weld bit??? I've gone through 5 and they keep clogging up.
Old 09-11-2013, 09:28 PM
68l30's Avatar
68l30 68l30 is offline
Default Re: For the Bodymen
The ones I use have a spring loaded center that hold the top panel while you drill out around the spot weld. It never gets up into the bit..
BIG
Old 09-11-2013, 11:00 PM
Any tip on where to get those? Only place I could find them local was China Freight...
Old 09-12-2013, 12:03 AM
68l30's Avatar
This one only says ...made in the USA. It's 3/8 in dia. Center punch the center of the spot weld and it cuts thru like butter. Drill speed is king, run it slow. I believe I got it thru Grainger or McMaster Carr. They do come in different diameters, I had one with interchangeable cutters, kind of like a Starrett hole saw set.
BIG
Old 09-12-2013, 12:11 AM
L78racer L78racer is offline
rota broach tools will work.
http://shop.blairequipment.com/Rotab...utters-s/2.htm
Old 09-12-2013, 11:51 AM
Mucho appreciation folks..........
Old 09-12-2013, 12:27 PM
x2 2 on Rotobroch cutters, you can buy individual size cutters several places. Stay away from the light duty Blair hole cutters, not enough beef and they bust easily.
http://shop.blairequipment.com/category-s/25.htm
And try this stuff too, awesome... [img]<<GRAEMLIN_URL>>/worship.gif[/img] Boelube paste on your bits, google Boelube, aviallable lots of places.
Old 09-12-2013, 12:37 PM
Yup, ordered the Rotabroach Master Kit. Thanks for the Boelube tip. Have some sub-contracts with Boeing so I guess I could give them some $ back........
Old 09-13-2013, 04:04 PM
Well, the Rotabroach 3/8 lasted for about 15 cuts (using Boelube) before the teeth broke, which isn't so bad.....ordered more bits...
Old 09-13-2013, 04:17 PM
68l30's Avatar
I wish I knew who made mine....Lasted a hell of a lot longer than 15 cuts, gotta be in the 100's. Notice how the cutting edge is more like a end mill not a hole saw.. I'm at work and I'll try to find who we got it from.
BIG
