Old 06-09-2013, 07:05 PM
enio45 enio45 is offline
Default 69Z - front stance
Looking for some advise - for the 69Z, when looking at the stance -I always believed that they were a little higher in the front then the back....say about an inch. Is this correct?
IF so - is there a measurement from the rocker molding to the ground I should be using -
Finally - if I need to get new springs (mine seems to be lower in the front by an inch) - who sells the correct springs for the proper stance?
Thanks guys for your help!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-09-2013, 09:08 PM
William William is offline
Default Re: 69Z - front stance
Trim Heights are in section A10 page 0 of the Assembly Instruction Manual. There are 4 points to measure; at the rockers a Z/28 was .38" lower at the rear.
Old 06-09-2013, 09:42 PM
yea, I see that....I believe that is the curb weight with full tank of gas
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-10-2013, 06:13 AM
parkbrau's Avatar
parkbrau parkbrau is offline
Have you read David's info re. Springs? Lots of good info there.
http://www.pozziracing.com/camaro_sp...fo.htm#SPRINGS
Look into Eaton, they sell the "correct" springs. http://www.eatonsprings.com/67-69camaro.html
Old 06-10-2013, 03:29 PM
looks like 6308's would do the trick.....to restore the ride heigth
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-11-2013, 10:03 AM
KevinW KevinW is offline
Ed, just be careful, A lot of times other springs get put in boxes from the factory that are labeled 6308s. I bought a set of 6308s from Amazon, there were 6320s in the box. Luckily, me having a vert, 6320s are the correct spring for my car (verts have an extra 50 lbs on the front )
PS, and I like the back end just a little higher than the front, about 1 inch. May not be factory correct, but with 14&quot; wheels and mono leafs, I need more height in the back [img]<<GRAEMLIN_URL>>/laugh.gif[/img]
69 327 convertible (driver)
Old 06-11-2013, 11:15 AM
I would not change the original springs front or back unless really necessary. If the car really sags ok but otherwise its a can of worms IMO. Unless the wheel wells are 6&quot; (just saying) above the back tires who would really notice?
Old 06-14-2013, 11:00 AM
miket1 miket1 is offline
Mine has original springs, the measurements at the 4 points are right on w/ the assembly manual, a little lower in the rear, I don't see many 69Z28's that have the correct stance, most are too high in the rear
69 Z28 Burgandy
