Old 06-04-2013, 09:11 PM
Default 4.10 trans gear reducer
It has been discussed here but I cannot seem to find it. Can someone tell me what gear reducer should be used on the 70 Z28, 4.10, M22, F60x15? I know it is the 666F unit but I do not know the ratio that is stamped on the unit. I do need one if anyone has the correct unit. Also need one for a 70 LS6, 4.10, F70x14. Thanks,
Rick
Old 06-05-2013, 02:10 PM
YENKO DEUCE REGISTRY's Avatar
Default Re: 4.10 trans gear reducer
I think it is 1 : 0.833
Marlin
Old 06-05-2013, 03:53 PM
Thanks M.
Old 06-05-2013, 04:14 PM
Part number: 1565208, goes with 'key'; part number: 867209
I have never been able to get this small assy to work properly, it spins way to fast or not at all..... [img]<<GRAEMLIN_URL>>/mad.gif[/img]
Marlin
Old 06-05-2013, 04:15 PM
mockingbird812's Avatar
Rick, FWIW, the '70 Deuces with E70-14 tires and 4.10 gears use the 1 : .833
This one resides on the side of the Roof Deuce M21 tranny.
Sam...
Old 06-05-2013, 04:38 PM
scuncio's Avatar
scuncio scuncio is offline
I have a nice 6477965 version available (same as Sam's) in case anyone is looking.
Old 06-05-2013, 09:02 PM
you have a pm
Marlin
Old 06-05-2013, 10:25 PM
Thanks for the picture Sam. I think that it may be different on the 70 Z's due to tire size. Also, from the photos I have been looking at it is the same unit the Chevelle uses though the one you posted would certainly fit a lot better! This is a shot of low mileage Z28 with 4.10 so I assumed that is the style these came with???
Old 06-06-2013, 01:18 PM
With a little help from Chris White and some GM books it appears that I need two of the .8241 units. Thanks to all for the help.
Old 06-06-2013, 03:50 PM
I've only seen the round type on the Deuces/Z28's, never the square type.
Marlin
