Old 06-04-2013, 03:22 PM
enio45 enio45 is online now
Default PVC Hose type
Any advise on this based on the what I am seeing below?
The pvc hose I see advertised on ebay periodically has a 90 degree bend on the one end. Im restoring a 69 Camaro SS 350/300hp auto car for a customer. We are trying to determine if originally the pvc hose for the 350 application had the 90 degree end or was it straight and just looped over to the other side of the motor?
Many pics I have seen are the Z28 and it seems to have the 90 degree bend on the pvc side - but cannot seem to get a good pic of an original 350/300hp car.
Thoughts/advise most appreciated as usual.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-04-2013, 07:01 PM
Material_Boy Material_Boy is offline
Default Re: PVC Hose type
Eddie,
All the Chevrolets I have seen with the PCV in the valve cover were 90 degree bend. A straight hose would look kind of oddball going the short distance to the front of a Quadrajet carb.
The closest I have to what you are working on is my 68 Nova SS survivor with a 350-295 horse
motor. It has the original hose which is a 90 degree bend. A straight hose would never work on my car because it would interfere with the air cleaner snorkle.
Dave
Old 06-04-2013, 10:17 PM
69VN's Avatar
69VN 69VN is offline
Absolutely! A straight hose would never work and fit like a molded hose. The correct pcv hose has a molded 90 degree bend and is secured with a special hose clamp. Here is an example on my '69 SS350 engine (*note--it is the same one that is being sold on ebay and HBC)
Hope this helps. Have anymore questions about how to critique that engine bay just PM me.
SAL
Old 06-05-2013, 02:25 PM
Sal,
No problems at all with that engine bay. Looks great!
Dave
Old 06-05-2013, 02:40 PM
Thank you guys'll for the info and pics,
I was told that these orig hoses have dates on the as well. Have u seen that?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-05-2013, 03:11 PM
mockingbird812's Avatar
<span style="font-size: 14pt"><span style="font-family: 'Times New Roman'">I recently realized what appears to be a part number and date on my PVC hose. The date of &quot;<span style="font-weight: bold"><span style="font-style: italic">03 18 9</span></span>&quot; is consistent with the build date of 06A for my '69 Chevelle. Here is a shot of the top of the engine shortly after I bought the car in 2006...</span></span>
Sam...
Old 06-05-2013, 04:50 PM
SammyG....coming thru with a great pic!!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 06-05-2013, 05:43 PM
Sam
Leaks like you need some new fuel bowl gaskets.
That PCV hose you show is a current modern day issue,that should have the last 2 digits showing the year..example &quot;03 18 98&quot;.
Someone then wiped off the last digit &quot;8&quot; to make it appear as though it was 1969,which,to be from 1969,woulda shown &quot;69&quot;..not &quot;9&quot;.
That,and other things on it are a dead give away.
Old 06-05-2013, 05:56 PM
Aha! Other dates on hose are the same way. I'll take a closer look to see if they were tampered with. Nice pun (&quot;Leaks like...&quot Like I said, that foto was when the Chevelle was &quot;new&quot; to me.
Sounds like you have an original, Rick. Post a photo please so we can all learn. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam...
Old 06-05-2013, 09:28 PM
I thought that the original PVC hoses had some ribbed lines like the original heater hoses do.I believe the hose on my 69 Z is original to the car and has ribbed lines on it with no markings from what i can see,maybe due to the age.Anyone else have a PVC hose with ribbed lines out there??
