Old 05-07-2013, 04:41 PM
madden madden is offline
Default 1970 yenko duece part #
hi
recieved tremendous help from a number of you already
need some more ifno if possible please
i need all the LT1 engine GM part numbers
-heads
-intake
-water pump
-distributor
-coil
-4 spd carb
-water pump and crank pullies
-altenator
-alternator bracket
-harmonic damper
-timing cover
-oil filter
-thermostate housing
-spark plugs
-spark plug leads
-radiator shroud
-fuel pump
-fan and fan spacer
cant think of any thing else...need the numbers so i can check what on my engine is correct and what i need to search for
thanks so much guys
regards
citrus chris
1970 citrus Yenko Nova
Old 05-08-2013, 02:28 PM
Default Re: 1970 yenko duece part #
I am guessing there are only a couple guys on this board that would know ALL those answers. I know just a few and am glad to share, but your best bet would be to invest in the 1970-74 versionof Colvin's "Chevrolet by the Numbers" book.
Also, part numbers are not always the same as <span style="font-weight: bold">casting</span> numbers, but many of these parts can only be id'd by the casting numbers, &amp; mostly, I just know the last three or four digits.
-heads 186
-intake 2110
-water pump 692
-distributor 11112116 (I think)
-coil
-4 spd carb I think 3972121 List #4555
-altenator 837
-alternator bracket
-harmonic damper
-timing cover
-oil filter
-thermostate housing 660
-spark plugs R43
-spark plug leads
-radiator shroud
-fuel pump
-fan and fan spacer 772 fan, no spacer, not sure of fan clutch designation
Old 05-08-2013, 03:30 PM
mockingbird812's Avatar
original FC off my 05D Deuce...
dizzy is 1112019...
water pump is -692...
Fan shroud...
Sam...
Old 05-09-2013, 02:51 AM
thanks guys
this gives me a start
if anyone else has info it would be appreciated
thank you all again
regards
citrus chris
