Old 01-13-2013, 07:39 PM
napa68's Avatar
napa68 napa68 is offline
Default Bead blast cabinets
What do you have? What do you like? What don't you like? What would you buy or what would you suggest to buy?
Tim
Old 01-13-2013, 10:41 PM
Default Re: Bead blast cabinets
Without hesitation, the Skat Blast 960 or 970 if you do a lot of blasting. If so I would suggest the 970 as the added room is well worth the price. I have been using them for many years and am very happy with them. http://www.tptools.com/dg/53_Abrasiv...-Cabinets.html
Old 01-13-2013, 10:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">Without hesitation, the Skat Blast 960 or 970 if you do a lot of blasting. If so I would suggest the 970 as the added room is well worth the price. I have been using them for many years and am very happy with them. http://www.tptools.com/dg/53_Abrasiv...-Cabinets.html </div></div>
Thanks for the link and advice Rick.
For a lot of us, floor space is also an issue. My planned work shop is only 28 by 30 deep. I am putting in a two post lift on one side. My workbench will be 10 foot by 3 foot, so my ancillaries better be space effecient.
The pic of the 970 shows a fender inside. Does a 70 chevelle or 69 camaro fender really fit? Is there room to work it around?
Let's say I am not planning on doing anything quite that big. I am assuming most wheels will fit fine in the 960. What might I be blasting that I would benefit from going up to the 970?
Lastly, I know my little 5 hp oil free compressor will not keep up. How much cfm (not what the manufacturer says - always seems to be about 30% short) will I <span style="font-weight: bold">realistically</span> need to keep up without having to constantly stop and wait.
Appreciate your input.
Old 01-14-2013, 02:35 AM
Donnie's Avatar
Donnie Donnie is offline
x2 what Rick said. I have this one and run it with a 7.5 hp 2 stage
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 01-14-2013, 03:08 AM
396L35's Avatar
396L35 396L35 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donnie</div><div class="ubbcode-body">x2 what Rick said. I have this one and run it with a 7.5 hp 2 stage
</div></div>
I have the same set up except I am running two compressors with 80 gal. tanks piped together and my system is over 15 years old and running strong.
Mark
Old 01-14-2013, 03:56 PM
Mark:
Two compressors. Never even thought of that. And I was going to give this one away when I build the shop. Come to think of if, I love this one for paint work because it is oil free and I don't have to worry about an oil separator, or ever having oil in the lines, so I could have a dedicated port just for paint.
Do you have any kind of check valves in place?
Old 01-15-2013, 03:14 AM
396L35's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Lynn</div><div class="ubbcode-body">Mark:
Do you have any kind of check valves in place? </div></div>
Lynn, I have three drains, four water traps, two regulators and about 30' of black iron line. I have never had a problem with oil or water getting into the cabinet. The only problem I have is I wish I bought a bigger cabinet at the beginning but otherwise I am happy with the performance.
Mark
Old 01-14-2013, 05:05 PM
Igosplut's Avatar
Igosplut Igosplut is offline
We have a 970 and put the housing extension on the side so you could blast rear end housings, etc. I also put another light on the right side, and a vibrator on the funnel to keep the media moving down. The om\nly bad part is the cheaper vacuum makes a shitpile of noise. flip side is the vacuum upgrade is three times the money (but very quiet).
WOT
Old 01-14-2013, 10:53 PM
I added the upgraded vacuum 4 years ago and it was worth EVERY penny. I am not nearly as fatigued at the end of the day from using it as I used to or maybe that is because I hired someone to do my shop blasting now........ [img]<<GRAEMLIN_URL>>/wink.gif[/img]
I am not sure a fender will fit as I have never blasted one of those but more importantly sway bars, rear end housings, etc, will fit without have to twist and turn to make it work. I would spend the little extra money for the extra length.
