- GM 10 ˝ Inch Inspection Cover $40.00
- Mint 526 Smog Exhaust Manifold, dated C-5-9 $575.00 - Original GM Leaf Spring Shackle Plates $55.00 - 67 68 Muncie Shifter Handle $100.00 - Heater Box Cover with Blower Motor 68 dated $80.00 - 1969 October Dated Jack/Mast (9J) $100.00 - Original AC Delco Dated Voltage Regulators (9F)working condition unk $25.00 - Original AC Delco Dated Voltage Regulators (7A - 7C - 7D)working condition unk $25.00 - Original AC Delco Dated Voltage Regulators (9J)working condition unk $25.00 - Used later version 69 Mint Deck Lid with no spoiler holes $475.00 - Pair of used original 69 Camaro RS Front Inner Tubs VERY nice shape $375.00 - Mint Set of late 67 Smog Exhaust Manifolds small block $350.00 - 67 Carb Q-Jet 350ci / 295hp $175.00 - 67 Non-Smog Exhaust Manifolds small block $75.00 - 67 Dated 8’ Timing Cover 5 – 67 small block $125.00 - 67 Nova V8 Oil Pan & Dip Stick / Pump $175.00 - 67 Nova V8 Engine Mounts $75.00 - 462 Cylinder Head Dated B 14 7 Checked / Magged $125.00 - Pair 633 Front Disc Brake Calipers Dated 52nd Day $160.00 - 69 Camaro Black Door Jamb Windlace with no clips $225.00 - 67 Camaro 2 piece Black Door Jamb Windlace $175.00 - 67 #348 Camaro Master Cylinder needs rebuilt $145.00 - 69 Z28 472 Intake Manifold $475.00 - 69 Non-dripper Finned 418 Valve Covers $475.00
67 Z/28 Butternut Yellow 69 Z/28 Rally Green 69 Z11 Pace Car (2) 69 RS/Z28 Lemans Blue / Olympic Gold 2010 2SS RS Aqua Blue 68 Z/28 Lemans Blue C7 Corvette 68 SS Lemans Blue 69 RS/Z28 Maroon JL8 66 Corvette Ermine White L75 |
69 RS washer bottle plastic screw caps. How many,3 or 6? Nice shape? Also, rear spring shackle plates, nice?
Thank you Loren
67 RS L30 3sp 10C LOS 69 RS/SS L78 M22 02D NOR |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: camaro cat</div><div class="ubbcode-body">69 RS washer bottle plastic screw caps. How many,3 or 6? Nice shape? Also, rear spring shackle plates, nice?
Thank you Loren </div></div> (3)Three Screw Caps. Both parts are in nice shape like header indicates. Can send pics if you like Thanxs Dave
Not sure if they are different but there are 3 caps on the screws that hold the bottle bracket to the bracket that is screwed to the inner fender and then 3 on the screws that come up thru the inner fender into that bracket. If they are different do you know which of the 3 they are? Do the shackles include the bolts & nuts?
Thank you Loren
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: camaro cat</div><div class="ubbcode-body">Not sure if they are different but there are 3 caps on the screws that hold the bottle bracket to the bracket that is screwed to the inner fender and then 3 on the screws that come up thru the inner fender into that bracket. If they are different do you know which of the 3 they are? Do the shackles include the bolts & nuts?
Thank you Loren </div></div> The caps are for the washer bottle and not for the screws the come up through the inner fender. Those even though listed in the assembly manaul I have not seen ever in my 30 years of messing around with camaros. I have had several unmolested RS Camaros and they never had those little ones. The shackles do not include the bolts and nuts, just the 4 plates or shackles. Thanxs
OK, I had to think real hard about it. Spending $100 for 3 small plastic caps seems crazy but this is the only set I have ever come upon. If they where assembly line installed, and you might send me a picture first,I'll go ahead. Let me know what I need to do. On the shackles,I really need the bolts & nuts the most.
Thank you Loren
What happened here? I said I would take them and left a pm but never heard back. Can I assume the screw caps are gone?
Loren
I will take the 1968 November Dated Jack/Mast (8K) $100.00.
Let me know shipping to 55811 and how you want to be paid. Thanks Mike
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
Dave , I will take the shackles if still available.
Buddy
69 camaro Z-28 burnished brown X-77 bought 1978 70 camaro Z28 forest green M40 black vinyl roof PROJECT 99 camaro SS Hugger Orange 6speed no t-tops 1 of 54 11 cts-v black diamond edition wagon 556hp GONE 15 camaro Z/28 white AC brand new |
My ph # is as follows: 484-753-1371. Sorry I typed in the wrong number above
